Neither did I, so I measured with an inductance meter (as posted on p.22 of this thread), right 790mH (590Ohms), left 830mH (605Ohms), suggesting a target of around 800mH (geometric mean). At first, I thought the coil resistance would disturb this measurement, but checking the instrument later on showed that it suppresses the real part (2%+5digits accuracy, 325Hz measurement frequency) quite well. (Btw.: exact mathematical accordance between resistance and inductance deviations of both channels!)
Due to the low measuring frequency, the coil winding cap doesn't have any influence on the result.
In order to extend the high frequency range as much as possible and limit <10KHz overshoot, (in my setup) I implemented the lowest attainable cap load of the el. chain.
All RFI caps removed from the preamp module and preamp chassis resulting in little less than 45pf load (the old-design, but very low noise opamp AD745 with huge input JFETs already contributes 20pF), short RG-180-based 50pF phono-cable, plus 15pF tonearm-cabling, totaling in 110pF. All values verified & measured. Assuming add'l 180pF as winding cap, the result from your quoted calculator is this:
One should note the nice low overshoot of 0.5dB around 6KHz and the attenuation of -3 to -5dB in the range where the cantilever resonance should be present. Unfortunately I don't have the widely used CBS test record at hand here, but direct-switch-over listening tests yield good correspondence between equally leveled and similarly mastered digital and analog program material...
