EJ3
It's close enough that the actual FR can easily be EQed with either analog or digital EG methods.Shure V15 III with Jico SAS/B measured on Technics SL-1210GR with KAB fluid damper:
Finally a Jico set-up that really works!Shure V15 III with Jico SAS/B measured on Technics SL-1210GR with KAB fluid damper:
See #517Anyone got graphs for the V15 V with SAS stylus?
Thing is in the real world, how many can do that? The V15V in original form (elliptical and MR) were if loaded with capacitance at 47k, flat to 10kHz with a 5dB drop to 20kHz followed by a death dive I recall. Loaded with less capacitance, the response tailed down in a straight line from 1khz to -5db at 20khz as tested by HiFi Choice back in the day. Loaded well, I loved mine until it met with an accident which fractured the cantilever at the pivot hinge point. There was a chap, ex Shure, on VE a few years back who was keen to resurrect the best styli for various models, but sadly nothing came of it..You could reduce the R to 30k I think.
MR at 47k 350pF is flat to over 20kHz.The V15V in original form (elliptical and MR) were if loaded with capacitance at 47k, flat to 10kHz with a 5dB drop to 20kHz followed by a death dive I recall. Loaded with less capacitance, the response tailed down in a straight line from 1khz to -5db at 20khz as tested by HiFi Choice back in the day.
About the same as I achieved with 770pf and 26k.... you can get more extension, at the cost of a slightly higher rise in the high end...This is the best what I could squeeze out of SAS/B on V15 V-MR:
@One could put the sytlus on the non -spinning record and record the phone stage output… whiLe playing some loud thumping sound through the speakers from say a CD player?As @SixtoeRodriquez says, “<Well> I wonder…”
If…
I want to do this myself.
Does anyone have experience with an RME ADi2 (fs), which is an ADC/DAC, can to advise what is the difference between the non ”fe” model, and the later fe model?
I want to do ADC to capture data (on the input side), and it would be nice if I could simultaneously do DAC on the out side.
