Mixing with open baffle speakers.
Ktacos
Howdy ASR. I've had some thoughts I wanted to share and contrast with others related to mixing music and open baffle speakers. Convention tells me not to bother but having not heard OB before my own experiments, I had to find out. Their function certainly has some supposed benefits that are appealing to me but I'm also quite skeptical of much of the claims I hear.
I setup a simple full range driver (Peerless TC9) on top of my tower speakers and filtered them appropriately with active filters (crossed around 600hz to a ported 7" woofer), tuned it all neutral, standard diy speaker affair. My initial listening impressions were kind of meh. It is a fullrange driver so the top end was just ok. It sounded kinda phasey and I'm not sure why, the width of the sound was strange, they felt wide but also narrow at the same time, as if the sounds radiation sort of runs into an invisible wall. Perhaps this is the full range driver beaming, I expected the beaming to make for a narrow sweet spot but that wasn't really the case. It mostly just made the HF information more localized to the speaker. My ear with what I assume is tube dysfunction seems to have appreciated a certain pressurization of the OB speaker. I do not know if this is correct at all but it felt like the speaker was pressurizing the room less if that makes sense.
Alright, time to load up a project and try to mix it. This part surprised me. I do genuinely feel that I was able to hear various elements of what I was doing better than I have on my boxed monitors. There are some areas that I have trouble with that can often feel like EQ movements are just not reacting in a manner that correlates with the EQ, but with these OB speakers I felt I could hear EQ movements much more precisely. I felt it was a bit easier to give track elements their own space EQ wise. As far stereo stuff goes, panning was strange to me and not particularly easy to deduce. Curiously one of the biggest surprises came in playing with stereo width of a track, be it a single track or the master bus. I utilize a few mid/side tools to achieve some perceived width increases and it was VERY apparent as to what these tools were doing. With my boxed monitors these tools generally delivered what felt like width but I could never hear what they were doing nearly as well as I could on these OB speakers. The smallest of application of M/S processing was very audible.
Overall mix translation felt good, tracks sounded how they were supposed to over various devices. I'd argue I was able to get the results I wanted a bit faster on the OB speaker, which means less trips back to the studio and less rendering and tweaking. At this point I'm not sure what to think. There's certainly a lot of good research on what makes a conventionally good monitor but other than the neutral response the OB speakers seem to go against convention, but here I am with results that make me want to keep going. I'm not too hesitant to make an lx521 clone to see what a more robust OB speaker can do for me.
Shot in the dark but has anyone else tried mixing on OB speakers?
I can't say I've ever seen a mixing control room with Open Baffle speakers.
I'm a mix from home kind of guy, most people are I believe. Studios going the way of the dodo for the most part.
I did find one snippet on the lx521 page, at least one person is using them.
"I didn’t have any other speakers that could reveal as accurate a sound stage, do so with tonal & timbral neutrality, and seemingly bypass the room … used for the final production stage mix qualification of all San Francisco Symphony SACD download releases that I’ve produced during the last three years; they are an indispensable tool"
This thread didn't get much traction, suppose there might not be much to discuss but I've been mixing on a little open baffle system in the living room and I have to say the results are probably the best I've ever gotten. I suppose there is something about OB that works for me. I'm getting better mix translation from a sealed rs180 woofer and a peerless tc9fd that is open sitting on top, than I've gotten with kali or genelec in the same spaces. I think I'm going to pursue this further and build a more robust OB speaker
I`m coming really late to this party, but maybe you are still interested in a better understanding of the little Peerless driver as a dipole speaker. Years ago I did some dipole measurements with that driver in small baffles. I mounted it on a 14x14 cm square piece of birch ply, just 3 mm thick in free air. Look at the measured horizontal response under different angles and compare it to the theoretical „Radiation of a moving circular piston in a finite circular open baffle“ as is discussed in https://www.linkwitzlab.com/models.htm in chapter A3 for the case b=2a. The accordance between theory and measurement is striking.
Don’t go by the 0° response (dark green), which is a singularity. Follow the 30° response (blue) which results for the most part in a simple and straight 6 dB/octave ramp.
For your personal case you might prefer a lower crossover point than the estimated ~ 1 kHz. That will be achieved by mounting the small baffle on top of the tower speakers you mentioned, flush with the box front. You get the idea when you look at the 14x40 cm OB, where I mounted the TC9FD too. It moves the crossover point to ~ 600 Hz.
It is adamant to use a really thin baffle. Nowadays I prefer Dibond/Alubond sandwich (~2mm) as baffle material and screw the driver from the back to the baffle. Those screws are the best points to hold the combination in place. Don’t use the thin baffle itself.
Very appreciated resonance after 1/2 year...:)
