Hey, I'm hoping I can get some advice on a potential speaker swap for my home cinema. Currently I am running a full Klipsch Thx ultra 2 set, recently I swapped the 4 atmos speakers over to the Kef ci200rr Thx which got me thinking about swapping the whole surround layer to the Kef product. I then picked up some
Kef ci3160rl and mocked up a baffle to try them out, when placed in the side surround postion the Kef seemed to draw attention to themselves unlike the Klipsch ks 525 bipole surround I have been using for the past 5 years. While using the Arc quick measure feature on my Anthem Avm70 I noticed how much sooner the Klipsch roll off compared to the Kef, is the ks 525 a bad speaker [in reference to frequency response] and would the flatter kef be more desireable? I don't really want to change the lcr which is currently the Klipch kl-650 thx as these throw a huge soundstage not something I think the kef could match without moving up to their dominus product.
Ultimately this comes down to 'timbre' matching with the lcr, the Kef do sound different and because the new speakers would need some re-modelling with my columns I want to be sure I make the right decison. I will add in some pics to hopefully give a better understanding of this project, the Klipsch lcr are behind a Seymour acoustically transparent screen.
Below are the arc measurements of the Klipsch ks-525, even on axis they roll off considerably towards 20khz.
The questions I am asking myself is this, are the Kefs the better product because of the flatter frequency response and is the mismatch im hearing due to timbre or just the fact that I am not used to them, the kef sound more direct vs the wdst design of the Klipsch. other considerations are that kef are placed in an open baffle and have not had any eq applied. Other revelations are that my side surrounds and rear channels are to high during this test procedure I lowered them and noticed a much better separation between the bed layer and the overhead speakers, there's definitely good advice in keeping the bed channels as low as possible when using overheads.
