- Joined
- Aug 3, 2019
- Messages
- 1,849
- Likes
- 2,919
...or the nimble, prop-driven fighter plane?i dont get it.. where's the car?![]()
beatiful nonetheless.....or the nimble, prop-driven fighter plane?
The problem is, equipment owners are requesting recapping as a service and are willing to pay for it -- and, as a pro technician trying to make a living, the customer is always right whether that's actually true or not. Electrolytic caps by their very nature tend to drift in value over time -- whether that drift and any associated ESR change are measurable, audible, or worth swapping in a few bucks of new parts to remedy is what's questionable, but considering the age of this particular unit it wasn't a bad idea and IMO extremely unlikely to degrade performance if competently done. Moreover, long-term electrolytic capacitor quality from the dependable brands has improved markedly over the past 40+ years due to technical advances, so wholesale recapping exercises can conceivably improve overall equipment longevity.Totally agree!
Not even really all that "similar" AFAICT -- very different physical layout and different output transistors (two rather than four per channel perhaps?) delivering considerably less power. I suspect the front end circuitry along with the two combination protection and speaker switching relays are somewhat "similar," but I'm too lazy to download manuals and compare schematics to confirm that.From Quirk Audio's Blog (a different Mitsubishi Amp but similar {no measurements but great pictures})
I'll add that some of those Japanese old caps fails all the time and create havoc, Sanyo light blue ones, CDE orange ones, matsushita CE Purple ones (I forgot the models but they have pretty colors) just like some signal transistors like 2SA726, 2SC1313 etc etc. Yes one can spend time testing and measuring or spend a couple of bucks just replacing those well know troublemakers and do some preventive maintenance.The problem is, equipment owners are requesting recapping as a service and are willing to pay for it -- and, as a pro technician trying to make a living, the customer is always right whether that's actually true or not. Electrolytic caps by their very nature tend to drift in value over time -- whether that drift and any associated ESR change are measurable, audible, or worth swapping in a few bucks of new parts to remedy is what's questionable, but considering the age of this particular unit it wasn't a bad idea and IMO extremely unlikely to degrade performance if competently done. Moreover, long-term electrolytic capacitor quality from the dependable brands has improved markedly over the past 40+ years due to technical advances, so wholesale recapping exercises can conceivably improve overall equipment longevity.
Dual Monaural & Dual Monaural The idea is the same.Not even really all that "similar" AFAICT -- very different physical layout and different output transistors (two rather than four per channel perhaps?) delivering considerably less power. I suspect the front end circuitry along with the two combination protection and speaker switching relays are somewhat "similar," but I'm too lazy to download manuals and compare schematics to confirm that.
Fair enough -- and they're obviously part of the same product line, which is why I suspect the unusual front end circuit and the two dual-function (protection and speaker switching) relays are probably identical or close to it.Dual Monaural & Dual Monaural The idea is the same.
If I meant to say that they were twins in circuit design, I would have.
But I did not.
Because what you say is correct.
But I was not diving that deep into it.
So, I guess that I must say that the INTENT of the design was also Dual Monaural but it was different in design. Jeez!
So we technically agree that we are both correct! Thank you!Fair enough -- and they're obviously part of the same product line, which is why I suspect the unusual front end circuit and the two dual-function (protection and speaker switching) relays are probably identical or close to it.
Funny, cassette decks were okay for cars and Walkmen, but they really were a pretty flawed delivery system for home audio. I was suprised that even the Nakamichi Dragon did not perform very well as tested here. That was the pinnacle of cassette technology.View attachment 449659
That massive cassette deck on the bottom is amazing. Looks like it belongs in an airplane cockpit.
I grew up in that brief period of the 80's when cassette tapes were the dominant format and I used to have boxes and boxes of them.
Can't say I miss them though.
I dunno, the emerald green seems a bit overwhelming and is clashing with the deep red of the frequency display. This is not an easy one, and the stock choice of moderately bright warm white may be hard to beat, but what about, say, a nice amber?
Indeed. Yamaha, Technics and Sansui akso had very nice gear at the time, as did Kenwood (even if their "Age of Plastic" designs were a bit eccentric). Same for their music, actually. (Japanese instrument makers became as good as they were for a reason.)Great times for Japanese electronics.
What a beautiful rack!I have an old Mitsubishi DA-P20 preamplifier. It was part of a modular lineup of separate components.
The preamp could be bolted onto a couple models of matching amplifier:
The resulting Franken-Receiver is slightly unwieldy.
Fortunately Mitsubishi had a pair of VU meters you could bolt onto the amps.
The matching DA-F20 FM tuner is remarkable and I still use to this day:
My preamp has had a bumpy life though.
I've loaned it out a few times. It was used for a business for a couple years. It's never been serviced. It has no obvious faults, and even the stepped volume attenuator, tone controls and switches have only the faintest noise. It has dual tape loops, MM and MC cartridge inputs, and boasts a 'dual mono' design with separate left and right input attenuators, plus separate tone controls for each channel. It boasts some killer specs.
18 Volt output, 10 Hz - 100 kHz frequency response, 0.002% THD for line-level devices, 290 mV phono overload for MM. I'm going to test as much of this as I can, compare to Mitsubishi's published spec. I'll also provide a similar dashboard of test conditions that Amir provides. I measured the unit with a QuantAsylum QA403. I measured, cleaned and adjusted Left and Right rail voltages to spec. There is a slight channel imbalance, more on that below. I was able to compensate for the imbalance with the handy input attenuators.
Feeding 2.5 V 1 kHz, gain set to provide 2 V output similar to Amir's dashboard:
This is great performance. The above is with the tone controls defeated.
With the tone control switch enabled and response in flat position there is a small 2dB degradation in performance:
Sweeping input voltage at unity gain results in the following output THD and THD+N:
I think that is outstanding. I cranked it all the way up to see if it can really deliver 18V:
It does put out 18V, even into 1 kOhm! You need a hot source, but it will do it if fed enough input voltage! I think you can spot weld with this.
Mitsubishi claim wide bandwidth:
I measure -0.2 dB at 10Hz, -1dB at 80 kHz; so slightly below spec but still great. Green trace is with tone controls defeated, the yellow is with the tone on and the controls flat:
I don't know if this is overpromising or due to age. The FR degrades when tone is on, but still impressive.
The tone controls have the following response for the +-2 dB, 6 dB, and 10 dB settings on bass and treble:
The tone filters roughly conform to the spec, have 2 dB increments.
The subsonic filter is different than spec:
Mitsubishi claims -6dB at 18Hz, but slowly rolls over an hits -6dB just below 10Hz.
Here is the performance of the volume control:
Maximum gain on the left of the chart is 16 dB. The largest left / right imbalance is at moderate listening volumes, in the range commonly used.
The stepped attenuator staircases in this region:
I cleaned the volume control, it didn't help with the channel mismatch or the staircasing. I measured the resistance of the ladder at each volume position, it tracks exactly the L and R gain. The L/R imbalance is due to the attenuator. I don't know if the resistive properties have changed over time, or if this is the same performance as new. It's still good performance, and the small amount of scratchiness that had developed is now gone. I am able to level the channels with the input attenuators for the measurements, but that isn't practical in real world since the imbalance changes with each attenuator position. It's not bad, but the nonlinearities in the volume control may be the most audible artifacts of this preamp since the rest of the line level performance is so good.
I'll test the MM and MC sections next. For instance, I want to see if it meets the 290mV overload spec:
