JeremyFife
There's never just one answer
From your original list; Yamaha AS501 with Elac DBR62s
The method of sub output doesn't matter much until you add a proper crossover. Your sub will take care of filtering and amplification in either case.
The WiiM Amp gives a better solution for sub integration, but it's not on your list and it has less power than the Yamaha.
You haven't said (or I missed it) how loud you listen, and how far you sit from the speakers . That's what determines your power requirements. The Yamaha should be plenty.
