drumphil
- Joined
- Dec 13, 2024
- Messages
- 90
- Likes
- 94
- Thread Starter
- #61
The comparison is intended to be between PCIE devices and USB devices, not USB versions. The figures I have just happen to be for USB3 mode, as tabulated in the link in my 7th post.Actually USB3 has no effect on latency compared to USB2, the microframe interval is the same 125us. However, it can deliver 16 times more channels (USB2 allows maximum of 1024 bytes per isochronous packet x 3 transations per microframe, while USB3 allows 1024 bytes per isochronous packet x 16 packets x 3 bursts).
As for the rest, I don't think that telling the average reader to get the spec sheets for all the internal components, and infer which filter mode is being used from other information provided, to figure out what the conversion latency of a ADC, DAC or combinded ADC/DAC unit, is really a practically useful approach for most people.
As demonstrated here, if we even if we assume the 1.5ms vs 0.5ms conversion latency with the behringer units to be round trip, not one way, it is still an example of a "free" millisecond of latency performance to be gained, and that is not an insignificant improvement in the usage cases outlined, and is hard to come by through other means.
The rest of the technical discussion, while interesting, is getting a bit far from the points:
Conversion latency can make up a non trivial amount of total system latency. The difference in latency between some converters is also non trivial. This information is useful, particularly to people in music and audio production.
If you're spending money on RME audio interfaces, because you do want the lowest latency possible, knowing that there is potential for 1ms to be gained or lost depending on which DAC/ADC converter racks you choose, is valuable information. A 0.5ms gain would still be valuable. We're not talking about half a percent either way with these differences.
Frequently in live audio there is more than one conversion takes place, and before that there can other instrument latencies, in my case the electronic drum kit. Anything I can do to reduce the total system latency helps.
