drumphil
- Joined
- Dec 13, 2024
- Messages
- 90
- Likes
- 94
While I think audio fidelity is well covered in the measurements reported in reviews here, as someone who works in the field of audio production, there is one thing missing that does actually matter when you're actually working with audio, beyond fidelity..
Latency!
It would be awesome if all reviews involving ADC, DAC, or just digital processing included latency figures. Because when you're dealing with real time audio as a performer, latency is critical. It doesn't matter how good your gear sounds if there is a 50ms delay somewhere in the signal chain between the performance, and the artist hearing it.
A practical example; I play drums, and I have electronic drum kits that I use to trigger virtual drum software. I have audio interfaces that are capable of low latency, but in that category of equipment, with the exception of some very recent and commonly expensive options, it is hard to get a really good quality headphone output.
I have an SMSL C200. Sounds amazing, better DAC than my audio interfaces, and much better headphone output quality, especially into lower impeadance headphones, or IEM's, but I would love to know for certain, if I attach it to the SPDIF output on one of my audio interfaces, am I going to be adding a bunch of extra latency? Perhaps it will actually perform better than the DAC chips in my audio interface.
Timing is critical to musical performance, and if piece of equipment compromises that by delaying what I hear, it is not a viable option. No if's but's or maybe's about it.
If the only audio interfaces/DAC's in the world that had really good latency performance had a noise floor around -70db, I'd be using that over anything else at any superior level of fidelity.
Would save a heap of time having these figures available, as it allows for a neat dividing line between everything that has good enough latency performance (which is of course subjective), and everything that doesn't so I don't have to waste any time considering those options.
So that's my request to you Amir. Latency figures. Doesn't matter much if you're just listening to music or audio, but makes a big difference if you're creating it, and this information is otherwise frequently nearly impossible to come by, outside of equipment specifically designed for audio production, and even there accurate figures can be hard to come by.
To me, this is like headphone output impedance, which is actually really important, but until recently a mystery with most equipment. Would be great to see latency added to the list of things that are no longer a mystery if we have the good fortune to have a piece of equipment we're considering reviewed by Amir.
Latency!
