Minimum Phase vs Linear Phase
Whilst I probably agree with what John is saying here, again it has to be put into context. How audible is an effect of moving the phase of say high frequency harmonics of a percussive sound? How much audible impact is there of changing the phase of a harmonic at 20 kHz that might be -70dB down?
In the DAC, minimum phase by default, of course.
But if you make resampler from a computer, depending on the recording, it may sound better in another way, something I have verified many times. Usually I prefer Intermediate, if the original sound does not convince me. If after the process still does not convince me, I delete the files.
I can differentiate between the Pass Band choiced. Of course, I talk about very good recordings with high DR.
Come back when you have performed some blind tests that verify your subjective opinion. ;)
If the recording is well made, the minimum phase is the right choice. But unfortunately there are and there were many bunglers and with a fairly resolutive system their bad arts or incompetence come to light when you listen to the recording.
On what basis is it the right choice. Please explain.
Just as a reminder, here is the classic illustration of the Gibbs phenomenon. The animation builds up a square wave from sine wave components, and you see the "ripple" that is simply a result of not using an infinite number of harmonics - so not having infinite bandwidth. It is not "ringing" as such.
Yes, would like to know that as well. In our thinking and research we use phase, however our hearing system acts on time differences. The outcome may well be that human hearing is much more sensitive to “phase” in low frequencies.
At low frequencies dacs and amplifiers are unlikely to have any issues with phase. It's only at their response top end where phase shifts are likely to occur.
I do not understand you. I have read bass and not basis :)
One example of my use of resampler with Intermediate is when I made a rip from CD made in 80 - mid 90. Usually the commercial music sounds bad or very bad, probably because it has a lot of jitter inside. Sometimes with a new SSRC resampler Intermediate you can cover up the jitter and make listening much more bearable, but sometimes not so.
And I don't understand you. :)
How can music have "jitter inside"? A ripped file is a ripped file - if there was enough jitter in the ripping CD drive to cause bit errors, there are incorrect bits in the file, otherwise the bits are the same as in the original. You can't store jitter in a file.
You have lost me I'm afraid.
Linear phase (in a well made recording, i.e. One that is properly filtered and bandwidth limited at half sample rate) is the right choice.
https://www.google.com/search?&q=minimum+phase+dac+why
-> The Linear vs. Minimum Phase Upsampling Filters Test [Part I]: RESULTS
http://archimago.blogspot.com/2015/07/the-linear-vs-minimum-phase-upsampling.html
I usually listen to recordings with acoustic (more) or electrified (less) instruments and almost nothing with synthetic instrumentation and voices manipulated with autotune as with current commercial music. With the first, and the second type of recordings, you usually have memory of how they sound live, and their tonality. With these recordings the best sound is with minimal phase.
I agree.
In those years many things were done wrong when digitizing. One of them, out of ignorance at that time, despise the importance of the jitter. Over the years it was verified that we are more sensitive than previously believed.
I guess that came from the preference of vinyl, without digital processing. Now digital technology is much better but the products created are horrible.
Did you actually read the "conclusions" part?
"If we can't find clear preferences with the amount of pre-ringing in the 99% steep filter as compared to minimum phase with no pre-ringing, then what are the chances that the comparatively small amount of pre-ringing with the default 95% SoX linear filter is of any concern?"
You make a lot of statements and claims, but I see very little logic or rationale - not to mention evidence....
Archimago had the following conclusion in part III:
As we know last week, statistically, indeed there was a preference for minimum phase filtering, but not strongly significant based on statistical data.
Yes, there was only one sample where the preference was actually statistically significant, and as pointed out earlier, the test was artificially exaggerated.
I guess it will have a lot to do with the kind of music used for the test. As I said, with acoustic instrumentation and voices without autotune, the difference is very evident to me.
For the rest, I have no confidence in the tests performed from the Internet. Blind tests must be in the same room and with a good stereo that does not have bottlenecks that prevent appreciating differences.
And, of course, without using foobar2000 as a software player, with or without the ABX plugin. If the source is a computer, it must be optimized to play multimedia.
- End off topic -
A few years back I was using a DIY WM8741 based DAC with an Arduino based controller.
The DAC had 5 (IIRC) different digital filters and I was never 100% sure my code was properly changing the filter as I could never hear the difference.
I think I was doing the right thing as all the other programming of the DAC worked fine. Now with my bought DAC I don't worry at all that there's no way to select filters!
