hi guys-
having an issue w/the export process of my MSO config to my minidsp 2x4 hd.
My setup is a 7.4.4 using a denon x4400h to a minidsp 2x4 hd. I have 4x martycube's w/lavoce saf184.03 drivers powered by 2x crown xli3500 amps.
I'm trying to get into basseq and have ezbeq up and running on my raspberry pi.
I have a really nice bass response in MSO and trying to import my settings over to the minidsp using the "save minidsp beq biquad text for this configuration".
I have left the inputs peq blank for basseq. i am able to upload my output "per channel" peq's and it works fine.
The problem i'm having is transferring over my xover biquads to the minidsp.
Everytime i copy/paste my xover biquads under the xover advanced menu, it'll also turn on a LW 48 db/octave hpf under the basic mode menu for my front left sub.
There are no links between subs.
When, i disable the LW hpf in basic and repaste the xover biquad to my front left sub and apply it, all the xover's for the four subs are yellow, except for my front left which is grayed out.
When i go back into my front left sub setting, the LW is disabled, but there is now nothing in the advanced mode biquad programming window.
I can take some screenshots but i think this video might be more helpful. Any thoughts?
Also, with this process, should the xover biquad be the same for all 4 channels bc that's what MSO is spitting out.
Basic biquad keeps activating
Attached is the cover biquad for my front left - all four look identical.
