MiniDSP with a separate DAC and Preamp
So, I've been playing around with REW and the miniDSP for the past few days and I've tried a few different EQ settings based on my measurements.
I've measured the L+R speakers together and individually and applied EQ settings for both these scenarios. My initial impressions are that it's made it sound noticeably worse, it's kinda sucked the life out of it.
I'll admit to being new to REW and I'm probably not getting the best out of it but it's been very underwhelming so far. I will persevere to see if things improve but any tips or advice would be appreciated.
I'm going to try Dirac over the weekend and see what kind of difference that makes. Hopefully, a lot as I can see myself returning the miniDSP based on it's inbuilt EQ alone. Personally, I had better results using the PEQ on the RME ADI-2 FS Dac.
For some the PEQ settings after a REW analysis are not suitable. PEQ by ear and find what turns your crank. Don't forget to put in memory your PEQ settings as you go..
Maybe there’s an EQ app for your iPad that can do what you want without having to change your hardware setup, especially if you just need to fix one little area in the frequency range.
Correct. You would also connect the subs to a DAC connected to the miniDSP, rather than using the amplifier connection.
If I was to use the volume control on the Flex would there be any issues with loss of resolution? I would essentially be attenuating the digital signal before it get’s handed off to a DAC.
I don’t fully understand the debate between analog and digital attenuation so I’m curious if there would be a reduction on quality versus my separate preamp.
You can lower the gain 48 dB (or more than 250 times) before any of the 16 bits get eaten up. Generally digital volume controls are not an issue.
Sorry, I don’t fully understand. Does that mean if I have the volume on the Flex set to -48db or lower I’ll be losing resolution?
Basically yes, for 16 bit content. Not that you would hear it, since what you loose will be below the noise floor of your room anyway. And some is even retained due to dither.
Just to agree and emphasize, -48dB is a factor of 1/63096 in power. In other words, extremely quiet. Not only the lost resolution be below your room's noise floor, it will be below your ear's noise floor.
Ok, thanks for that.
So, essentially there isn’t gonna be an audible difference between my separate analog preamp and the Flex?
You’d need a second DAC for the sub, and connect it to the subs low-level inputs. That way you can crossover both speakers and sub separately. Hopefully you ordered a UMIK as well. You’ll need it. A simple DAC will do for a sub. Should set you back around €$£ 100.
Would this DAC be good enough?
I would not expect an audible difference, based on the specs. The Flex is good enough so it has no audible defects and adds nothing to the sound, except the manipulations which are deliberately added. I don't think anyone could detect its presence based on a proper blind test if all its filters were turned off.
I appear to be asking the same question in a separate chat. I had not picked up this thread in my search.
If OP @Probelou has any recent experience, with the outcome, I'd be very gratefuk.
(Not trying to hijack OPs thred)
My initial experience with the miniDSP Flex was a little underwhelming.
I started with this signal chain: miniDSP Flex > DAC > Preamp > Poweramps > Speakers (L+R and Sub). I use a Rel subwoofer hi-level connection from the speaker terminals on the poweramps. I completed some measurements with REW and implemented the filters using the PEQ on the miniDSP. The resulting sound wasn't great, it kinda sucked the life out of the music.
Then I upgraded to Dirac Live. Using the same signal chain I completed the Dirac process (measurements and exporting filters) and the results were pretty good. Dirac done a great job of flattening out the dips and peaks from the room measurements. Annoyingly, Dirac wouldn't allow me to save the project so I couldn't experiment further with different curves without doing another round of measurements. There is a clear audible difference with it enabled and some aspects are definitely improved but I'm not so sure about others. Again, it does feel like it's taken some of the life/sparkle/magic, whatever you wanna call it, out of the music. I'm pretty sure with some tweaks to the curve I could get it sounding pretty darn great but it'll need another round of measurements (hopefully, I'll be able to save the project this time).
I'm currently trying a different signal chain of : miniDSP > DAC > Poweramps > L+R speakers and miniDSP > DAC > Subwoofer. I wanted to use the miniDSP to implement a crossover rather than using the Rel hi-level connection. I've set a linkwitz Riley 48db 80hz low pass for the Subwoofer and the same high pass for the main L+R speakers. I'm not using any PEQ or Dirac with this and have only done limited listening but I could immediately notice the subwoofer reaching a bit lower with improved dynamics. I'll need to spend some more time with this and experiment with different crossovers as the blend between the sub and speakers didn't sound quite right to me.
If anyone has advice on tuning the crossing over, LR or Butterworth etc... it would be appreciated.
After my initial underwhelming experience I've put in quite a bit of time and I'm slowly starting to get some good results. There's definitely a learning curve to all this and if you're looking for a simpler plug and play experience I'm not sure this approach would suit.
One key thing I learned is to make sure you have some headroom with the volume control, otherwise you may hear distortion. I was assuming any boosting would automatically have been factored into the volume, but it's not. It's obvious really but took me a while to figure this out. Also, it only really applies if you're using a separate Preamp as you'd be running the miniDSP at 0db. While using my separate Preamp I needed to run it at -10db to allow for any boosting that Dirac was applying, apparently 10db is its maximum boost.
A question for any miniDSP owners using Dirac. It's only 2ch on the miniDSP Flex so how would this work while using the crossover setup? Would it treat the L+R speakers combined with the Subwoofer as 2 separate full range speakers in the same way it does when using the signal chain of miniDSP Flex > DAC > Preamp > Poweramps > Speakers (L+R and Sub)?
All advice is welcome as I'm still learning.
Yes, Dirac Live see's two speakers, no matter what is connected downstream. You need to set crossovers, delays, and anything else you need before running Dirac.
This is definitely the signal chain you want, as opposed to using the speaker levels on your sub. For crossover, I'd recommend a LR24 at 80Hz between the speakers and the sub. LR48 is very steep for sub integration, and likely won't blend as nicely with your mains. Without DSP, rooms dominate subwoofer response, and when those big peaks are taken away, and if you are used to that sound, then Dirac will sound pretty different at fist. It may take your ears a bit to adjust to a more neutral response. That said, if you can post some REW sweeps people can see what's going on and chime in.
The LR crossovers are better for sub integration than BW, so you are on the right path.
I'm using my Flex as the preamp, so maybe that's the difference, but I've never had any distortion at all, and Dirac does cut the level automatically. Not sure why you are getting distortion.
Did you set the delay on your sub with REW before running Dirac? If not, you probably want to start over. If your sub is further from your ears than your mains, you'll need add delay to your mains to let the sub catch up. If your sub is closer, then delay the sub instead so the mains can catch up. A good starting point for delay is 1ms of delay per 1 foot of difference in distance. Also make sure your crossover is set the way you want before dialing this in, because that will affect the interaction. After setting an initial delay, take a REW sweep of each channel and see how it looks, then adjust the delay and rinse and repeat until you get the best blend between your sub and mains. You'll see your peaks and nulls move around as you change the delay.
And yes, this stuff can take a long time and a lot of learning to get dialed in, especially if you are limited as to when you can run calibrations and sweeps (most domestic partners don't love calibration tones it turns out). I added two additional subs to my office system on February 26th this year, and I was not in love with the configuration and kept messing with it until I finally nailed it on April 11th — determined by looking at the dates between the first/last Dirac run since adding the additional subs.
What's the process, when using REW, to set subwoofer delay?
Also, have you experienced any issues with your Flex where it just stops outputting audio? This has happened to me a few times and I've needed to unplug it from the mains then back in again to get it working. I'm connecting to it with USB and I've read the jitter in a USB signal can cause it to do this.
The process I use is exactly what I outlined above. I adjust the delay in the miniDSP, then take a quick REW sweep to see how it looks. All manual... no automation here.
I have never had this happen. miniDSP support is very good, so I'd contact them directly.
In this thread I describe how I get and set up the delay on mains IR to the sub. There might also be more info in it that you find useful.
Hi everyone,
i'm trying to achieve the same thing as the OP (high pass my speakers and use them together with a sub, anyway i don't want to get rid of my r2r dac)
and i was reading everything here, anyway i;m not sure why there is the need for a secondary dac in this chain "miniDSP > DAC > Poweramps > L+R speakers and miniDSP > DAC > Subwoofer."?
minisdp can't do 2 outputs? one analog with a high pass filter and another one digital with either the full frequencies or even low pass?
thanks
