miniDSP vs active analog crossover
Lyrion Streamer on rpi , with camilladsp and sound interface with 4 , 6, 8 or more outputs , for crossover and room correction. Best than wiim, but diy
I have Lyrion running on my NAS. I like it for my streaming from my music library, but not for streaming from Tidal. In my setup I run a WiiM Ultra, outputing digital over USB to my Raspberry Pi running CamillaDSP. I am very happy with the setup. But, non-technical users sometimes have a hard time getting CamillaDSP properly configured. Nonetheless, the CamillaDSP thread has helped many people in this forum to get it running properly.
If I were you I would keep the beautiful Cambridge as a streamer, get a MiniDSP Flex as digital x-over/DSP/volume controller, and connect both digitally. Then also get a MiniDSP Umik2, as without acoustic measurements, subwoofer integration will not work. You can do all measurements using REW software which is available for free.
So far this seems like the best plan. Cambridge streamer (because I already have it) and minidsp Flex with DAC (so I get analog outputs). I could also opt for the Flex with digital outputs and use my Cambridge DAC, but thin I'd need the mini again for streaming.
I already have the Umik1 and REW and have been using it for years with my HT setup. Also, I used to own a minidsp 2x4hd. Returned it because I didn't like the sound quality on the highpass.
I have both a Umik1 and a Umik2. They both work great for subwoofer integration and room correction using REW. The OP probably is better off saving money and going with the Umik1. Regardless of which microphone is used, its calibration file should be used in REW.
Yes, I've got the Umik1, cal file, and REW already.
I am a somewhat familiar with the miniDSP PEQ setup and I believe room measurements with REW can be saved and directly loaded into miniDSP products to do room equalization (or to at lease give a baseline to start with). How do the WiiM products do their room correction? Can they also load REW files? Do they have both linear eq and peq filters?
Regarding the three DACS in these components:
Cambridge Audio cnx v2
WiiM Ultra
miniDSP Flex
Which is best?
Any links to comparisons/reviews appreciated.
miniDSP is very limited taps processing power, to me poor value for money
> How do the WiiM products do their room correction? Also very limited, but automated.
Ultra is good value if you actually need the other features, maybe their RoomFit will be good enough for you. The crossover is 2.1 only though, not stereo subs.
> Can they also load REW files? Neither can afaik, need to enter IIRs via PEQ manually.
An RPI5 or an old PC gives you All the Freedom to learn DSP and choose whatever filters you like.
I don't want a PC on all the time, but once you've established "the optimum" you have a baseline to compare using the less powerful options.
Or see how you feel about that issue
You would not be able to actually hear any differences if you set up double-blind testing
You're probably right, but so may reviewers seem to think they can hear differences it makes me wonder.
I suppose I could connect the digital out of the WiiM Ultra into my cnx v2 digital in to use its DAC for comparison. Would that cause the mains to be delayed compared to the sub channel on the WiiM though?
I doubt if so it would be noticeable.
Plus the Wiim has timing delay / sync functionality
WiiM, no.
MiniDSP, yes, at least some of them. E.g., I have loaded REW EQ files into my Flex HTx.
I think this may only matter if using FIR filters. IIR filters, such as the type REW will generate, are much more efficient. I use IIR filters with my Flex HTx on all 8 channels, and I have no issues whatsoever.
I agree.
This limitation is related to FIR filters:
I assume the OP will use manual PEQs and high/lowpass filters and delay, and the Flex should offer enough flexibility with 10 PEQ per input and output channel, plus x-over:
The WiiM does not support FIR filters at all if I am correct.
Yes REW can export FIR, and yes those are the ones, especially at low frequencies that challenge the low-tap convolvers.
It is true that many prefer filter creation tools like rePhase, Acourate, or Audiolense
processing those, you're much better off with a PC or RPI5 for doing your convolving
at least for the learning stages.
HiFiBerry DAC8x
Darn the add-on DSP unit is not compatible with DAC8x ?
What do you reco for low cost DSP on a per-pair basis that is?
Maybe best to answer here if you're willing
so as not to divert this thread too much?
TIA
Which WiiM product has the streamer + DSP + DAC?
The Ultra is just 329. Is the quality really on par with the Cambridge Audio CNX v2? Seems rather inexpensive.
EDIT: After some reading it seems listeners are tending to like the cnx v2 sound better than the WiiM ultra.
All streamers which provide bit-perfect digital feeds into modern DACs sound identical. Anyone who claims to hear a difference has not performed a proper blinded test with all voltages set to be identical.
I have an older Cambridge streamer feeding my ADI2 Pro. It sounds identical to a laptop feeding the same DAC,
Most of the audible differences are attributed to the DAC and its supporting circuitry. The input stream should be identical and not a factor.
Have you seen the review of your streamer? It's DAC and surrounding circuitry are state of the art. But they are not significantly better than alternative DAC circuits. What the review shows is that your streamer has no audible differences between it and other similar devices.
https://www.audiosciencereview.com/...audio-cxn-v2-measurements-streamer-dac.31915/
I may have misunderstood your previous post. I thought you were saying all streamers sound identical if they are feeding the same DAC (your ADI2 Pro).
Yes, I read the review and the remarkable 115 SINAD measurement. Which is much higher than hundreds of other DACS. But this brings up another question. This SINAD was measured at just a single frequency and power level. Clearly the DAC does amazingly well at 1KHz. The harmonics and noise are so far below threshold. But what does this say about other frequencies and input levels? How did the 1K SINAD become the single metric used in ranking?
Not saying it isn't relevant, just wondering if it is really a good indicator of rolled-up performance.
