Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Welcome to ASR. There are many reviews of audio hardware and expert members to help answer your questions.
Click here to have your audio equipment measured for free!
Y’all are out of your mind if you don’t think $3500 with ART included is not a highly competitive price for this pretty niche class of product. Honestly when I clicked on the email, I was expecting it to say $5-6k.
Of course the actual quality of the product, not the manufacturer’s promises, remains to be seen. For instance, I do hope they manage to provide a decent remote as mentioned by someone else. The one that came with my HTx is like a $1 Alibaba piece of generic plastic. The pause/play button doesn’t even do anything (I assume it works with their streamer devices).
This is a little more niche and not well known but it is quite easy to control minidsp via raspberry pi either through automations and custom graphical user interfaces with minidsp-rs. It's possible to source detect by input watching an AVR and auto switch minidsp presets accordingly. The remote is a joke though the Flex HTx remote is the same one that is included with the 2x4 HD. Not that SINAD matters ....but having a SINAD higher than a Trinnov processor has got to say something indirectly about its build quality.
Does anyone know if this will be able to connect to a music server (via SMB or similar) or use Qobuz/Tidal Connect like the SHD devices? Is it a Roon endpoint? I see that it has ethernet. Not a big deal, can always just connect a Wiim Ultra, but I’m curious if they put all that in there. Will be nice to control the device on the miniDSP control center over the network rather than with a direct USB connection (I assume this is possible).
(This conversation was regarding loading your own FIR filters into MiniDSP)
I don't think this is true for Dirac enabled MiniDSP devices, although I could be wrong. The MiniDSP that I borrowed had FIR on the input stage, which was locked by Dirac. I couldn't figure out how to upload my own FIR into the device. As for this device, I would also be paying for a Dirac license that I will not be using.
You are correct if my memory serves me correctly, some MiniDSP devices allow you to upload your own FIR files if Dirac is not enabled. With the Flex HTx, though, you cannot, presumably because it does not have the processing power to handle FIR on all 8 channels.
If I were to build a surround sound system that needed more than 8 channels, the Tidal16 is the DSP unit I would use for audio, assuming there is not some really bad news that comes out about it. I don't think there will be, though. I had a SHD and currently use a Flex HTx. I have been very impressed with both of them.
Have we resolved whether it's 2.1 or not? I couldn't keep up. Reddit appears to be convinced it is not but that might be an echo chamber effect. I'm not smart enough about video to know.
HDMI 2.1 naming scheme is a mess, you need to check what kind of feature or resolution supported on this device as they are no longer mandatory to support a specific bandwidth which is important as a. AV hub
Let's be real the target market is cinemaphiles or audiophiles. Last I checked movies are not 120fps. Any serious gamer is probably using headphones or a nearfield setup anyways. Not only that just plug source directly to display for 120hz and passthrough audio.
Full transparency, I haven't had an AVR in years but 0.01 ft and 0.01 ms are pretty much the same thing.
speed of sound = 1125 ft/s
1 ms = 10^-3 s
0.01 x 10^-3 x 1125 ft/s = 0.011 ft
Also, you are only getting 0.01 ms delay at 96 kHz sample rate as one sample is 1 / 96000 x 10^3 = 0.010 ms. At 48 kHz (like the Tide16 runs at) you can only do 0.02 ms. Still good enough IMO but important to be accurate if you are comparing device capabilities.
Sorry, but 120Hz is not only used by competitive gamers sitting at their RGB lit computer desk (those kinds are typically way beyond 120Hz these days), it's a standard feature on consoles. I would not get an AVR/AVP without it. Yes, you can bypass it and just use eARC, but then why buy something clearly designed as a video hub that you can't use? Maybe they could make a cheaper version without the HDMI switching.
What? Tariff is a percentage of the price of the device. By baking the licensing into the product, you are essentially paying tariffs on the licensing. If you could purchase the licensing separately, and the product was cheaper, then you wouldn't pay tariffs on those costs.
People are saying this is expensive, but these will be connected to a constellation of Genelecs? Or 12-channels of Purifi Eigentakt/ Benchmark AHB2/ McIntosh/ Bryston?
The custom $50-100k home theater installers will love this precisely because it does a lot while not being the Denon that the client can find at the local Best Buy.
I think MiniDSP made the right choice going way upscale (but I won’t be getting one).
I wonder if this device will be able to display it menus as an overlay upon the current video stream?
(This is a nice feature that most AVRs offer).
On that topic, one of the minor annoyances of using eARC (e.g. to overcome the lack of 4k 120Hz with a games console) is that connection via eARC prevents you from being able to see such menu overlays.
Hopefully the web interface will be good enough for that to become the main method of remote control. (Allowing you to operate it without needing the menus to be displayed on the tv).
