You say that but you're not on the miniDSP side trying to increase profit margins. Folks laughed (and I laughed with them) but perhaps it does take an MBA to see both the consumer and vendor side and understand where that happy middle ground is that sets the market price!
No argument with any of that. MiniDSP and .............. others have almost certainly done the right thing for their individual cases.
I say that $100 isn't a lot of money, but it is. I used to work in a production environment for 8 years, and the amount of time, effort and money we put into reducing the BoM, touch time and waste was absolutely enormous. Consumer electronics is even more cost-sensitive, and adding one cent to the total cost will be a huge battle.
I'm sure miniDSP have taken the right decisions. StormAudio I'm not so sure about.
As others have mentioned in other threads/posts audio electronic devices, for example, amplifiers, they don't know or care what kind of sound waves they receive at the input, as long as they can output the amplified signal without altering it(the non sinusoidal waveform), their job is done. That is, if output=input X k, with the waveform unchanged then the device has done its job! I am sure that "transparency" in that sense, can be, and have often been verified by many with the advance of oscilloscopes, spectrum analyzers etc.
This is a key point. Years ago I would have disagreed with you , but not any more. Now I'm completely satisfied you can assess an amplifier with sine waves.
But that's not what this is about. It's not about using sine waves to measure the performance of an amplifier against the requirements.
It's about whether to use sine waves to establish what those requirements should be in the first place (and then you can test with sine waves to verify performance).
For the reasons given in post #1598, I think you get a different requirement for transparency (1) when you test audibility with sines and (2) when you test with other signals.
I don't really why that would be,
and it absolutely doesn't matter why.
For the sake of argument, suppose you listen to a wide range of sine waves varying from 10kHz to 40kHz, and you vary the bandwidth of the system reproducing them. You would find that when you extend the system bandwidth beyond 20kHz, it no longer makes a difference to what you hear.
However, if you test with other sounds that have an actual spectral composition extending well beyond 20kHz, I think that when you extend the system bandwidth from say 20 to 25 kHz, there would be an audible difference (and not just from young ears). I'm suggesting you would get a different answer to what the bandwidth requirement should be for transparency. I don't know what it would be. 21kHz? 40kHz? I've no idea. The point is that bandwidth needs to be enough for transparency for all sounds, not just one sound.
Suppose you establish that the requirement is 30kHz. You can go ahead and specify that for your system. Then you can test the bandwidth of each component in the system using sine waves, and that will prove transparency in that respect.
