I was referring specifically to
points 3 and 4 in the miniDSP link below. miniDSP itself notes that the room significantly affects measured response below about 600 Hz, which is why outdoor measurements, nearfield measurements, or other special techniques are often used when integrating active speakers.
https://www.minidsp.com/applications/digital-crossovers/active-speakers-dirac-live
My understanding is that this is not required to the same extent with Trinnov, and I was simply wondering whether the addition of Dirac ART changes that for miniDSP. In other words, does ART make in-room active speaker integration substantially easier, or is it still basically the same miniDSP workflow underneath?
Lsc is probably correct that these deeper loudspeaker-integration features are still mostly Trinnov territory. That is not meant as criticism of miniDSP; it is just the reality that capability has to be viewed in light of price. Trinnov costs about as much as a low-end Toyota, so some difference in functionality is to be expected.
