Throwing my hat in the ring to describe my use case and ramble. My current setup uses the Flex HTx which is wonderful but I have no surround and too few channels even for stereo. My current setup is stereo 4 way plus rumblers on the seat with their own compression/filters daisy-chained off the Flex's L/R Woofer ouputs.
I foresee the Tide, as a pre/pro/XO doing a few things for me:
- Eliminating the rumbler daisy-chain and the associated secondary DSP box
- Center channel, prob 2 way active
- L/R Surrounds
- Adding 2x spatial channels or going active 2-way with the surrounds
My experience with the Flex has been massively positive and I'm very excited for the prospect of reincorporating surround in my space. Just having some simple DSP derived surround at a low level will help my asymmetrical room to sound more consistent for stereo, that's the biggest failing in my space, is you can "hear" that one side is open. Horns and multisub mitigate it but ultimately it's wall vs. no wall and having more system-sourced filler will reduce that effect when managed/EQ'd correctly.
Most users here seem to prefer speaker systems with integral XOs, so my massively multiway active use case isn't the norm around here. But I think that's what makes this unit so special- a broad toolkit, with very transparent electronics (the low noise... absolutely necessary for my setup) facilitates a setup like mine, where low noise and the flexible channel-routing with modern codecs is the value add- 5.2.2 is about as much as this space could tolerate.
