Dougey_Jones
- Joined
- May 27, 2020
- Messages
- 747
- Likes
- 690
Do any AVP’s do that?Assuming there's no chance in hell this will automatically detect which input is playing?
I assume the Marantz ones do through HDMI CEC. My older Denon 8500 receiver does this (switching between Apple TV & Blueray player connected to the receiver and a cable box connected to the TV). When it works, it’s cool to have the receiver switch inputs on it’s own.Do any AVP’s do that?
Trinnov is catering to a niche market. Partially overlaps with Storm at best, but then not really as Storm relies on Dirac that is quite simple all things considered.
Number of options and adjustments on Trinnov is mind boggling and no other company opted to go there as they produce consumer products. Trinnov is a custom instal unit - does not even have the common CEC. And they have best customer service support in the bizz - which for that money they should.
All of the devices we’re talking about support EARC, so you just connect the input devices into your TV. The HDMI port on the Flex HT and HTx is intended to be connected to a TV. Since it does not support Dolby/DTS, you need a blu-ray player that can decode to surround PCM (not uncommon I believe) or a TV that can (not as common these days).
MiniDSP’s devices are for tinkerers, not really an out-of-the-box solution.
Does it really replace DSP? It is about an equivalent of RPi 3, I doubt it can process 16 channels ART.It is interesting to me that they are moving away from the Analog Devices SHARC platform and appear to be using a commodity ARM Cortex A53 x4 1.8 ghz SOC.
Every other MiniDSP uses a 400 mhz core (based on a 2010 design) which can do stereo Dirac. While that had DSP optimized vector instructions, Raspberry Pi 3 is more than 10x as fast at vector math to do 16 channel Dirac.Does it really replace DSP? It is about an equivalent of RPi 3, I doubt it can process 16 channels ART.
Folks who swear by eARC/ARC have never had their older OLED TV turn on mysteriously by a device just to receive some nasty burn-in.All of the devices we’re talking about support EARC, so you just connect the input devices into your TV. The HDMI port on the Flex HT and HTx is intended to be connected to a TV. Since it does not support Dolby/DTS, you need a blu-ray player that can decode to surround PCM (not uncommon I believe) or a TV that can (not as common these days).
Personally, I use the HTx with a Sony A95L (TV) connected to an ATV (for streaming; works well with Plex/Infuse also) and an Ugoos AMB6+ (for Kodi/Plex, blu-ray rips). MiniDSP’s devices are for tinkerers, not really an out-of-the-box solution.
I realize that it's not apples-to-apples, but I was doing 16 channel FIR convolution on stereo inputs using BruteFIR on an OG Athlon processor 'back in the day' (around Y2K). Sure, partitioned convolution and latency that would be difficult to manage in a video system, but the raw throughput available on any modern-ish CPU is pretty significant.Does it really replace DSP? It is about an equivalent of RPi 3, I doubt it can process 16 channels ART.
Probably plenty capable.Looks like this could also be used as a crossover/processor for multiway active speakers? Any ideas on how capable the "Quad Core ARM processor / 1.8GHz " is in terms of DSP?
Possibly it's better now than you remember? I do use eARC currently and have never had an issue.Folks who swear by eARC/ARC have never had their older OLED TV turn on mysteriously by a device just to receive some nasty burn-in.
Compatibility issues and a near infinite combo of home equipment have always made eARC/ARC more of a dream than a practical application.
Isn't it CEC, which turns on/off TV? Probably works without ARC.Folks who swear by eARC/ARC have never had their older OLED TV turn on mysteriously by a device just to receive some nasty burn-in.
spec sheet says 2.1 for earc, but video passthrough 60hzHdmi 2.0? Seriously?
possibilities endless looks like full matrix rerouting so any crazy type of speaker/midbass/subwoofer would work.Looks like this could also be used as a crossover/processor for multiway active speakers? Any ideas on how capable the "Quad Core ARM processor / 1.8GHz " is in terms of DSP?
You can use eARC separately from CEC.Folks who swear by eARC/ARC have never had their older OLED TV turn on mysteriously by a device just to receive some nasty burn-in.
