Keel in mind too, the Tide 16’s DR is more like 127 dB.I also got a bit tripped up by their comment, but it is true that if using solely digital volume control then the DAC noise level would be fairly fixed regardless of whether the DAC is at quiet output or loud. If the noise is fixed then turning down the signal would bring the two closer together, making the noise/hiss audible after 26dB of amplification.
Analog volume control is usually preferable for quality for this reason, it allows the signal at time of creation to put maximum distance between itself and the noise floor, where you then bring both down to the desired level afterward. AVRs and some AVPs do this, block diagrams (when published) will indicate.
Ironically after doing some of the napkin math on ideal gain staging (@mdsimon2 did this above, great work!) I ended up warmer on AVRs. I hate to come to the conclusion that using high performing gear like miniDSP and Hypex amps can result in worse performance somehow, but I can’t see a way to very easily manage analog volume control in these types of setups.
My projected >115 dB is SINAD (based on spec of 118 dB), not DNR.
