Where you have contradictory evidence like that, my view is that you should take the result with the highest positive result, rather than the lowest negative result.
That's an example of a negative outcome, where subjects were unable to discern a small difference. There are lots of those.
My point is that the limit of audibility should be set at the smallest discernible difference that CAN be detected, rather than the largest difference that can't be detected.
My reason for focussing on positive results is because a negative result doesn't prove anything. You can't prove that something doesn't exist - only that it does exist.
Here's a disgraceful example of pseudo-science by Ashihara et al that concluded "the detection threshold for random jitter was several hundreds ns for well-trained listeners under their preferable listening conditions". Audiophile bashers all over the World cheered, because it was seen as scientific proof that a high level of jitter is inaudible.
What they actually did was simulate the effects of jitter by modifying the audio data itself (see their other papers) and get their listeners to play the samples on a PC, DAC and audio system. Firstly, if you know anything about jitter, that's not jitter. Second, their transport was a PC, which is full of noise and jitter. Maybe if the test was done today it would be different, but this was 20-odd years ago. The researchers simply assumed they had a good source, and didn't do anything to quantify the performance of their baseline. This is analogous to testing a linear amplifier using a tone generator with 1% THD, and concluding that the amplifier has 1% THD (this is why the APx555 is so good -
because its signal generator is so good). Ashihara concluded that their subjects couldn't hear hundreds of ns of jitter, because the source had hundreds of ns of jitter. It's an (extreme) example of a negative result obtained because the test wasn't good enough
If you get a negative test result, it could be for two reasons - because the sonic difference you're looking to detect is too small to be audible, or because the test isn't good enough. The problem is, if you have a negative result, you don't know which one it is.
If you get a positive result (achieved with proper scientific rigour of course) then you know BOTH that the test is good enough AND the sonic difference is audible.
EDIT: I don't want to go any more off-thread, so I'm just going to dump all my audibility links here. The 2014 Meridian AES paper is also available in full, now.
It's not just one or two positive test results. Whenever I probed deeper, I kept finding more, so there's lots out there, and probably lots that I've never seen.
Audibility of "typical" Digital Filters in a Hi-Fi Playback - Page 4
Audibility of 20kHz brick wall filtering
Audibility of Group-Delay Equalization | IEEE Journals & Magazine | IEEE Xplore
Detection threshold for distortions due to jitter on digital audio
Double Blind tests *did* show amplifiers to sound different | Audio Science Review (ASR) Forum
E-library page - AES
HD high noon
High-resolution music with inaudible high-frequency components produces a lagged effect on human electroencephalographic activities - PubMed
https://ieeexplore.ieee.org/document/9450008/
Inaudible high-frequency sounds affect brain activity: hypersonic effect - PubMed
Inaudible High-Frequency Sounds Affect Brain Activity: Hypersonic Effect | Journal of Neurophysiology | American Physiological Society
Mastering Captured Vinyl For CD
Modulatory effect of inaudible high-frequency sounds on human acoustic perception - PubMed
Proof that DACs CAN make a difference! - Blind ABX Testing - YouTube
Sampling Rate Discrimination: 44.1 kHz vs. 88.2 kHz
Successful ABX of 24/96 vs. 16/44.1
The human ear detects half a millisecond delay in sound | Aalto University
My own conclusions:
This is the 21st century, and we don't use CRT TVs, VCRs, film cameras, typewriters and fax machines any more.
The bottleneck in digital audio should lie in
storage & distribution, and not in expensive reproduction equipment.
High Resolution audio definitely makes a difference, I'm even more confident of this now than I ever was.
The difference between CD and HR is tiny, often inaudible, and isn't worth pursuing in most cases.
24/48 audio is fine for film soundtracks, it's only well-recorded music that shows the benefit of HR.
MiniDSP and Storm process at 48kHz, and I'm sure they will stay that way. Better filters outweigh higher sample rates.
