…or any other pre/pro on the market for that matter. Hey, it’s a fantastic box and a great value, but it has the same problem that every other pre/pro has.
The problem is two fold:
• It doesn’t have linear phase crossovers (or support for them)
• Its DSP only supports processing at 48hHz
(if there is a unit that has all this, it has to run around $30k or more)
For the average person, neither of these will be a disqualification. Downsampling the digital signal to 48k will probably be inaudible and the phase errors introduced by IIR filters aren’t objectionable (no more so than passive speakers), but this isn’t ideal for a system that will also be used for audio mixing and mastering.
I, on the other hand, need more than any current pre/pro offers. Unless there is something out there I haven’t discovered, my only solution is this:
• Mac Mini with 32GB of RAM and several TB of storage
• MOTU 112D AES interface
• A whole slew of Topping DACs
• Dolby & DTS media players for MKVs
• Apple Mainstage for the main audio frame work software
• FabFilter Pro-Q 4 plugin for linear phase EQ and crossovers
• Other software for routing between apps
• Remote duties will be handled by an iPad
• Somewhere in this will be room correction (haven’t really spent much time considering that)
• Down the line, all of the KEF LS50s will be replaced with biamped DIY speakers and DIY subs. The speakers and subs will be cardioid.
With extra software I can add multiband dynamic expansion, upmixing and ambience generation for enhancing stereo audio.
This will be a fully modular, completely upgradable system with no limitations.
Complex? Yes, very. That is why it’s infinitely upgradable. This is not plug and play.
Expensive? No, actually, not when compared to pre/pros by Storm, Lyngdorf, Trinnov and DigiSat (all start at $20k or much more).
The computer, software, interface and peripherals will be around $4k. Topping’s best Sabre DACs are $700-800 each and outperform any pre/pro.
Again, the Tide 16 is fantastic, but not quite good enough for my very extreme needs.
