- Joined
- Jun 5, 2016
- Messages
- 3,504
- Likes
- 6,002
No. One in each of the four corners of the front wall.I'm experimenting with sub placement with ART, so I'm curious about yours. You have two subs in each of the two front corners?
Not “my” standard. 7.1.4 what pretty much all immersive content is actually mixed in.Maybe that is your standard for an immersive configuration. I have 9.1.6 and in my opinion, for some media the front wides are essential, and it does enhance ART.
I have never seen subs in the upper corners of the front wall. I’m intrigued.No. One in each of the four corners of the front wall.
There are twelve different presets available, and, if I recall correctly, 24 different slots for Dirac filters. Selecting a preset will select the Dirac filter with the same number automatically, e.g. preset 5 will load the Dirac filter in slot 5. Details in the manual.Can the Tide16 store multiple speaker presets? With my x4800h, I have two presets - one is 5.4 (for video watching) and the other is 2.4 (for music listening). Each preset is calibrated separately with ART and has three profiles (default curve, baby bass boost, and big boy bass boost). Switching between the two presets (and the Dirac profiles in each) is fast with the Denon remote.
Can something similar be accomplished with the Tide16?
And the presets can each be calibrated independently and addressed by Dirac? Do you have to reboot the unit to switch speaker config?There are twelve different presets available, and, if I recall correctly, 24 different slots for Dirac filters. Selecting a preset will select the Dirac filter with the same number automatically, e.g. preset 5 will load the Dirac filter in slot 5. Details in the manual.
Truly you should open the manual at the miniDSP website, but no you don't have to reboot.And the presets can each be calibrated independently and addressed by Dirac? Do you have to reboot the unit to switch speaker config?
Hey @airs a little apology, I was kind of snippy with my RTFM answer, not my intention.Truly you should open the manual at the miniDSP website, but no you don't have to reboot.
The manual explains explicitly what is saved with presets. And there is another feature, "scenes", that may be relevant, which saves different aspects. Just do a search on presets and scenes in the manual, and all will be explained.
One thing confuses me, and I've spent a lot of time in the manual. The Dirac slot matches the preset slot, yet there are 12 presets and 24 Dirac slots, what am I missing? My unit won't be here for another 6 weeks so I'm kind of flying blind.There are twelve different presets available, and, if I recall correctly, 24 different slots for Dirac filters. Selecting a preset will select the Dirac filter with the same number automatically, e.g. preset 5 will load the Dirac filter in slot 5. Details in the manual.
I agree it is confusing and I don't have a filter in one of the higher numbered slot to investigate. There is a web application, accessible from your phone or computer, that gives access to additional features. I can see in the documentation of the api that there are ways to call specific Dirac slots. Someone created an app (using Claude) to create an good interface for this, I haven't tried it, and I doubt that I will, but if you go to the Tide community support board at miniDSP, you will see two topics, one is called Tide Remote and the other Unofficial Home Assistant Integration, take a look at what is there and maybe post a question to find out if the remote app or web controller access the additional Dirac slots.One thing confuses me, and I've spent a lot of time in the manual. The Dirac slot matches the preset slot, yet there are 12 presets and 24 Dirac slots, what am I missing? My unit won't be here for another 6 weeks so I'm kind of flying blind.
I doubt that I'll need more than few slots, more just a spot of confusion in an otherwise very nicce manual. The matrix mixer also leaves me a little curious.I agree it is confusing and I don't have a filter in one of the higher numbered slot to investigate. There is a web application, accessible from your phone or computer, that gives access to additional features. I can see in the documentation of the api that there are ways to call specific Dirac slots. Someone created an app (using Claude) to create an good interface for this, I haven't tried it, and I doubt that I will, but if you go to the Tide community support board at miniDSP, you will see two topics, one is called Tide Remote and the other Unofficial Home Assistant Integration, take a look at what is there and maybe post a question to find out if the remote app or web controller access the additional Dirac slots.
This assuming that my memory is accurate on the number of DIrac slots!
If I'm correct, presets 1-12 are linked to Dirac slots 1-12 (with 1-9 addressable using the remote) and anything beyond that you need to use the web app or the remote app referenced in the topic. There are several people who have a strong interest in automation and access via phone or computer who will have a great deal of knowledge to share. I'm not especially interested in software and am almost totally ignorant on these under the hood features. For me, it is just about the audio.
It's key for many applications like testing subwoofers.matrix mixer also leaves me a little curious.
This was my initial thought as well, i.e. that I would need different speaker setups for multichannel and stereo but this is not the case. ART works great with both multichannel and stereo using just one speaker configuration. You can have different ART presets for these configurations but I have not bothered with it as the results are great with just one preset.Can the Tide16 store multiple speaker presets? With my x4800h, I have two presets - one is 5.4 (for video watching) and the other is 2.4 (for music listening). Each preset is calibrated separately with ART and has three profiles (default curve, baby bass boost, and big boy bass boost). Switching between the two presets (and the Dirac profiles in each) is fast with the Denon remote.
I agree completely, and even more so, there is no point to having a configuration with fewer speakers, as ART is always better with more speakers.This was my initial thought as well, i.e. that I would need different speaker setups for multichannel and stereo but this is not the case. ART works great with both multichannel and stereo using just one speaker configuration. You can gave different ART presets for these configurations but I have not bothered with it as the results are great with just one preset.
Different speaker configurations are not stored in scenes neither presets and creating different speaker configurations is quite a tedious task and I am not sure where these would be stored for recalling/switching between but rest assured you won’t need them.
My understanding is that measurements for surround sound are recommended to be done with the mic pointed at the ceiling (90 degrees calibration file), whereas for stereo it should be pointed at the mains. But perhaps what you are recommending is to measure at 90 degrees and let stereo be upmixed?I agree completely, and even more so, there is no point to having a configuration with fewer speakers, as ART is always better with more speakers.
I suppose something like what @airs described could be done with the matrix mixer, but as you clarify, there is no point to it at all, though it is easy enough to create three sets of ART filters and assign each of those to a preset.
It has nothing to do with upmixing. This is an understandable misconception. Example:My understanding is that measurements for surround sound are recommended to be done with the mic pointed at the ceiling (90 degrees calibration file), whereas for stereo it should be pointed at the mains. But perhaps what you are recommending is to measure at 90 degrees and let stereo be upmixed?
What you can do is download the 14 day demo of the Dirac suite (including ART) for your computer, and make a temporary setup with your computer to play back and test ART to get an idea if what it does is something that you are interested in, before spending thousands more. I believe it only supports stereo plus subs, but it should give you a good indication.Hi Team,
Can anyone sell the Tide16 or put me off it?, I'm on the fence about it, I currently have an Anthem AVM70 (running 7.2.4 with plenty on AMP power and Speaker wattage - PB3000 subs open port (but read perhaps I should run them closed in this small room...), which is pretty good, but I have a small room 410cmX360cmX240cm high, so bass is an issue, have lots of treatment in the room, but the whole ART sounds like the go, I know the Tide16 only has hdmi 2.0b which I'm ok with, but I cant really find any real reviews or too many 'This thing is great' posts, what is the general feeling about the Tide16, should I get one? or wait for something else?, thanks in advance... Ryan
I think you should seriously consider ART whether by this model or another AVR. ART is very effective with multiple subwoofers at reducing resonances.Hi Team,
