miniDSP Tide16 AV Processor Review
Rate this AV Processor:
    Votes: 3 1.0%
    Votes: 7 2.3%
    Votes: 45 14.5%
    Votes: 256 82.3%
What amps do folks plan to use with this?
You'd better be factoring in the cost of 16 Topping B200s if you don't want to bottleneck performance!
I'd expect that once you engage processing and bass management, there is at least a 10 dB hit.
This is true of all AVPs, but we do not know how big the hit is since that is not measured, anywhere as far as I can tell.
SINAD is great baseline, but this is a not a real use case for any of these devices.
- Rich
Probably in the minority, but I wish it had Auro3D so I can use the upmixer. I really do enjoy it that much. Enough to wish for it more than additional HDMI ports and the 2.0 thing.
Still a very compelling product that I would consider for my next AVR.
The black box includes, legacy analog path and volume control and hardware DSP processors with unclear limitiations.
The software approach of the Tide16 seems like a better architecture.
Lack of HDMI 2.1 and QMS-VRR are a big deal.
The upcoming Emotiva LXP processor is on my list.
I'll be keeping an eye out for Tide-16 stroke 2 with HDMI 2.1.
- Rich
Am I missing something? The specs in Amir's second post clearly state it is HDMI 2.1 with VRR etc. It's also slotted, so I assume it is modular to be updated in future if needed.
Edit: Ah, I see 2.1 "compliant"..
HDMI capabilities (FlexiSLOT)3 x In, 1 x out HDMI switch, HDMI 1.4/2.0b compliant
Resolution: 4k60Hz UHD, 18Gb/s input/output capable, 24/25/30/50/60fps
4k to 1080 conversion for HDMI1.4 compliance
HDMI 2.1 EARC/ARC compliant
HDMI 2.1 Variable Refresh Rate (VRR)
HDCP 2.3 compliant / Dolby Vision Compatible
So much negativity. Y'all sound sore about it. Just don't buy it.
I like this device a lot and have one I'm transitioning to for Atmos. It's an awesome product for the tinkerer. I agree it's not a good device for the timid or the dumb.
And It's unpolished. I'm getting some screen glitches on Apple tv music when transitioning between songs. I'm sure I can report it and they will fix it eventually.
It has a couple of 2.1 features, but the bandwidth is limited to 2.0b. That means limited to 4k @ 60fps.
People are allowed to voice concerns or issues, not just fawn over stuff.
So... anyone whose needs aren't met by this device is timid and dumb? Seems a bit judgemental.
Been waiting for this one and it does not disappoint!
I'm currently running a Denon AVR-4700h as a pre/pro, outputting to a Dayton Audio active crossover to Hypex amps but planning to replace the Denon and Dayton with the Tide16 at some point, in part just to simplify the setup, and in part because there does seem to be a bit of loss in quality (and noticeable raising of the noise floor) from the signal being converted to analog by the Denon receiver and then converted back to digital by the Dayton for crossover processing and then back to analog.
Wonderful to see such fantastically low noise and distortion here, plus built-in Dirac is a huge plus.
Yep. Along with not supporting HDMI 2.1 that makes it a nonstarter for me. Too bad, as otherwise it's pretty faultless. If I was looking to go full active this would be so close to perfect for AVP duties.
Also, a model with half the channels would be welcome.
Curious why this is an issue for so many. I used to run everything through my receiver, but after having some issues with delay (and upgrading to a display that supports 4k/120, which my receiver does not), I started plugging my more demanding devices (PC & 4k bluray player) directly into my LG OLED TV, and then running a single eARC HDMI connection to the receiver. Works great, and I use the HDMI ins on the receiver for my older gaming consoles which output 1080p.
Because acting as a video hub is part of the point of an audio/video receiver? There's no reason to have multiple HDMI inputs if the intent is not have the video routed through it.
You can be sensitive about it if you like, but I'm not wrong.
Yeah, I think you are. Calling anyone with different needs and wants than you in an electronic device a cowardly idiot, effectively, is pretty objectively wrong.
Any reason it seems to be limited to 8 pcm channels?
Good question - to ask miniDSP. I can only speculate - to have a compact unit, which will suffice for many customers.
:facepalm:Limited HDMI inputs, HDMI 2.0, no OSD and no return/repair support in the US market. It's a better buy in other countries that don't have restrictions on trade of course. $4,300 US is a big ask for some of the hardware and software sacrifices.
It measures well, but it would be cool if the unit could be sent to another ASR staff member willing to take the time to review some of the actual A/V features including codec switching speed, system temp during use, how quickly does the unit go from idle time to start up, DiRAC implementation, earc management, potential clicking during source changing, how well does it transition from multi channel video to single channel music playback, etc. I would also like to see the unit paired to a purifi (or NcoreX) amplifier to see how well they match in real life usage. I am also curious the actual video playback on a large 65" - 82" OLED panel is impacted by these HDMI 2.0 ports.
The volume delay also seems like a problem for a AV unit at this price point.
* Can't pass 4k 120Hz signal from games console or PC.
* If TV does not support format (such as DTS) then eARC won't work.
* Can't use on screen overlay if using eARC.
* Can't define per input presets as all on the same HDMI input.
* For LPCM, tv capabilities could cause fall back from 24bit 192kHz to 16bit 96kHz or 48kHz.
My only quibble with the review is Amir categorizing the $3500 price as “incredibly low.” I don’t think $3500 can be described as a “low” price, and certainly not “incredibly low.” Perhaps it is a fair price, or is a price lower than its competitors, such as processors from Storm, Trinnov, and the like, but it’s not a low priced component.
I did a quick estimate in the non-review thread. They're definitely making money off this thing!
Finally processor with SOTA performance and reasonable price.
