miniDSP Tide16 AV Processor Review
Rate this AV Processor:
    Votes: 3 1.0%
    Votes: 7 2.3%
    Votes: 44 14.2%
    Votes: 256 82.6%
Does that price include D-ART?
Any limitations on the number of filters that can be deployed?
Sorry if the above have already been mentioned, I did not go through the whole thread.
Obviously there is not a similar kind of limitation in the number of filters as e.g. Marantz has in Dirac ART - and there aren’t any reports from the current users of running across such a limit. This is what the development team stated about the issue in June on the miniDSP forum:
Maybe best to communicate with Marantz/Dirac support to understand better where the limitation comes from as we could be wrong but we believe that it's related to the size of the MIMO matrixing. That's a wild guess. We don't have that limitation on our side. Tide16 does NOT have a crossterm filter limit. We have 16x16 MIMO = 256 crosspoint capabilities. Hoping that clarifies.
The price includes the entire Dirac suite with ART, though as @Mort mentions the price doesn't include tax (VAT, IVA, tariffs etc.).
There are no limitations on the number of Dirac filters at this time. Someone from MiniDSP made a comment that 200 filters or more would be excessive, but they are not restricting.
There's really just no comparison b/w the computing power of actual PC/mobile CPUs (Tide16) vs D&M products (SHARC chips meant for DSP).
About HDMI and eARC + HDMI Box.
Yesterday got Tide16 delivered, started basic configuration, did not run Dirac calibration yet. Updated firmware, set correct wiring for 5.2 etc.
So, for now I found interesting setup with Tide16. Basically you can run sources into processor for HDMI 2.0 (4K 12bit 4:4:4 chroma <60hz) and you can run sources into TV (4K 12bit 4:4:4 120hz) and use them both. This is how I did it:
- connect Tide16 to HDMI IN + eARC (one port) On your TV
- connect all 4K 120HZ sources to TV into appropriate 48Gbps ports
- connect the rest to processor (or whatever left)
Operations of setup:
- use remote of Tide16 to select HDMI sources (1-2-3) on Tide16 when you run sources that connected to Tide16 + select HDMI to which connected Tide16 on TV (eArc). Example my BluRay player.
- or select eARC on Tide16 and select 4K 120HZ on TV. Example my PC.
No box required, the part that makes it work that Tide16 TV Output is eArc input, so connection between TV audio passthroug and Tide16 video Passthrough is basically runs via one port / cable. Depending or your source selection on Tide16 and TV.
Did not test setup with HDMI box yet (got this one BK-4929). I will test it in my setup later, but if eARC has not lag, issues on my "old" OLED, I probably will stick to that compromising setup with running sources into TV and Tide16.
I put BK-4929 to the test. TL;DR; it works, if it continue working as it was yesterday, I will keep it.
- sources PS4 Pro, XBOX Series X, PC with 4K / 120hz / HDR output.
- output to LG C9 and to Tide16 -> hypex/KEF R11 + Center + Surrounds/Monolith Subs (5.2)
In initial setup it was unstable, sometime blinking and trying to negotiate something between devices, I think it was related to fact that I connected video output from box to TV into HDMI with eArc on TV. When I moved it to pure HDMI, all negotiation issues stopped.
About metadata and pass through
1. XBOX Series X could pass uncompressed Dolby / DTS, checked in games and Blu Ray: settings in XBOX is Passthrough and Uncompressed settings for 5.1 or 7.1 layouts
2. PS4 Pro allows to passthrough bitstream, but for some reason asks encoding DTS or Dolby, which is wierd, if its passthrough, why you need select one. Not sure if PS4 Pro actually does passthrough as device, so it is not on HDMI Box, but on Sony.
3. PC, after installation of Dolby app, selecting Home Theatre sound settings in Windows for Dolby, it started output 5.1 sound (identified the Tide16 layout automatically, Tide16 "upmixed" it to 5.2), all metadata went through, working in Games, tested in Cyberpunk 2077. I assume it passed all metadata
CEC works as well, volume control from TV, Mute etc.
Did not have any letancy issue so far, but I did not run Dirac live ART yet, so not a final configuration.
p.s. There is eArc button on box, I do not know what it does, but without it pressed eArc works as expected anyway. With it pressed, all handshake process repeats every 3-5 minutes, so it introduced instability.
p.p.s. Mystery solved with eArc, it’s basically source sends signal to box, box sends it to TV, then sends it to Soundbar/processor. Per page 12
Many thanks. Could you elaborate on the bold bit? Did you mean that you could run regular HDMI to an HDMI input the Tide16, but not run eARC into the Tide16 output?
You are welcome.
Originally Box was connected to HDIM with eArc on TV, and I thought its created a conflict, then I moved from HDMI with eArc to regular HDMI (without eArc) and regular 3-5 minutes blinking stopped.
Just finished Dirac ART calibration, set my target curves, put on profile to load using one button on remote (via miniDSP control app). Max delay settings on subs about 10ms, rest of speakers under that value (Dirac decided to pick left surround as baseline with 0ms delay).
Anyhow, don’t see any sound delay in games, so far all functioning well via hdmi box.
So how does it sound with ART? That Orei BK-4929 looks like exactly what I need to add eARC capability to my old plasma TV for the time being so thanks for confirming that it works.
ART adds quite a significant amount of delay. You can’t tell from the system offsets, you need to look at the impulse graphs within the ART software.
I had Dirac ART running with Mac Book before, difference only that I added surround group and center group as support.
Sounds very clean in linear in bass region. Art quite different from DLBC, I had it before as well.
check this message, there are more boxes available to solve that task: https://www.audiosciencereview.com/...tide16-av-processor-review.73525/post-2691032
Thanks again.
Forgive me, I'm confused. I don't think the manual is clear about how the switch works.
There are two elements to the eARC functionality - eARC from the TV, and eARC to the soundbar or processor.
The manual doesn't explain which one of those two functions is controlled by the eARC button.
I think the answer is the TV connection, but I'm not sure what happens to the other output.
It's starting to look like eARC is the ONLY audio connection from the switch to the processor.
Can you tell us which connection you used on the Tide16? Was it one of the three "HDMI IN" connectors, or was it the "HDMI OUT / Output/EARC/ARC"?
EDIT : After reading the BK-4927 manual, I think the 4929 has only an eARC connection to the soundbar or processor, and the 4927 has only a conventional HDMI connection to an input of the processor (and not the "output").
Can’t wait to buy one, this will probably be the last AVP I buy.
Thanks again.
Yep, it was confusing.
It has one eArc for audio bitstream, that goes to Tibe16 (on box its called "to soundbar"). And another to TV (also mark as eArc but for different reason). It's how I connected.
the eArc button/function allows you to control volume from TV (over CEC) if you connect TV HDMI with eArc to box and enable that function. For me it was unstable, non stop negotiations between TV / Tide16 / box. When I disable it and moved to regular HDMI on TV (non eArc) all worked without any issues / turn on and use it.
Which connector did you use on the Tide16? Is it the one marked "HDMI OUT / Output/EARC/ARC"?
eArc and HDMI out on Tide16 its the same port. So yes.
I repeat entire chain here
Sources to box into HDMI In (1-2-3-4)
box to TV from TV to regular HDMI In on TV (HDMI 1 in my case with 48Gbps)
box to Tide16 from eArc ("to soundbar") to HDMI OUT/EARC on Tide16
eArc function on box is off.
That is it
Whatabout:
1. Sources to switch
2. Switch to TV HDMI (non eARC)
3. TV eARC to Tide eARC
(eARC off on switch) (you can also use other tv HDMI inputs for more sources, and also Tide’s HDMI inputs for more non-2.1 needing sources)
If you have eARC off it feels that then you should just connect to tide’s normal hdmi (not the earc/out). I think it (the switch) then works as a splitter.
That won't work with the BK-4929 because it only has an eARC audio output.
To use an HDMI input on the Tide, you would need something like an Orei BK-4927 or 927, or a Feintech SW411 or CorsaHD SW41H21A.
But then you would lose the eARC performance advantage.
