welwynnick
- Joined
- Dec 26, 2023
- Messages
- 1,558
- Likes
- 1,968
Find anything that is better and cheaper.3500! Jesus, I mean, Kraff!
Lets hope so, releasing hardware that is 10 years behind in terms of feature set is quite sad for a higher end product.I wonder if minidsp will ditch 2.1 and jump to HDMI 2.2 in their next version, and that was the plan all along
There might be some FRL2 source products in 2027, they will only be high end graphics cards. There will not be switch chips which is what you need for a AVR/AVP for a while.Lets hope so, releasing hardware that is 10 years behind in terms of feature set is quite sad for a higher end product.
Confirming this worked.Make sure that you have Device Console rev. 1.25 Beta 8
Boot up your Tide
Open and go to settings in the Device Console (on the left)
Enable check for updated software
Enable Beta releases
After you have done that, when you open Device Console it should ask you if you want to install the update. If not ...
Go to your Tide16 (in the console)
Click on the Tide Software to bring up the dialog
Enable Receive Beta Updates
Download and then click reboot.
Should work.
Could you expand on this Nuvoton chipset, was the AV20 affected?Of the things ASR has tested other than the Tide 16 that have balanced outputs which are in the ‘green’ category I count 7 designs. Some of those don’t count as they are two units in the same series such as Anthem AVM70 vs AVM90.
Anything using a Nuvoton chipset, for example any Marantz, won’t do QMS correctly due to them not having shipped updated chipset after the specification debacle which meant the first gen chipsets didn’t work correctly.
Please list the units you think fill the criteria since I suspect the list is null or just a couple of extremely expensive processors.
Yes, Denon, Marantz, Arcam (At least previous gen), Anthem, Yamaha and JBL Synth are all Nuvoton based. A lot of other brands likely are too.Could you expand on this Nuvoton chipset, was the AV20 affected?
Excellent!No box required, the part that makes it work that Tide16 TV Output is eArc input, so connection between TV audio passthroug and Tide16 video Passthrough is basically runs via one port / cable. Depending or your source selection on Tide16 and TV.
Some HDMI 2.1 switches only output eARC if they get an eARC audio input from the TV, but according to Orei, the BK-4929 "sends audio from your eARC TV or the connected media sources to eARC-enabled sound-bars such as Sonos ARC or Beam", so it should be good. Something to watch out for.Did not test setup with HDMI box yet (got this one BK-4929). I will test it in my setup later, but if eARC has not lag, issues on my "old" OLED, I probably will stick to that compromising setup with running sources into TV and Tide16.
Not missing anything. Just someone sharing a success story. It won’t necessarily be true for someone else’s setup with different equipment.Isn't what's described above the default eARC setup with any device? Nothing special about tide16 in that regards. Or am I missing something
That's good to know. What TV are you using?
The question is not whether that set up will work with any device, the question is whether and well it will work with the Tide, and so we are all interested in @AudioKC's results. Helpful for those who want both HDMI 2.1 and the Tide's superior audio reproduction.Isn't what's described above the default eARC setup with any device? Nothing special about tide16 in that regards. Or am I missing something
It should be, but I don't think it's always the case. Some TV's just don't play ball.Isn't what's described above the default eARC setup with any device? Nothing special about tide16 in that regards. Or am I missing something
believe the return policy is not the greatest in the States (open to correction).
‘All sales are final, No exchange, No refund, No return policy.’Hoping all the equipment plays nice in an ARC/eARC setup is a risky proposition since I believe the return policy is not the greatest in the States (open to correction).
Does that price include D-ART?3500! Jesus, I mean, Kraff!
It is but the US price is closer to $4300 with tariffs.Does that price include D-ART?
Any limitations on the number of filters that can be deployed?
Sorry if the above have already been mentioned, I did not go through the whole thread.
