Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Welcome to ASR. There are many reviews of audio hardware and expert members to help answer your questions.
Click here to have your audio equipment measured for free!
Hello, what is better my Denafrips Arce streamer + eq roon (with Umik1 + rew) or. only Minidsp shd studio - dirac live? I have big problem with nonsymetrical room. I know second options is simple, but first mybe better sound? Did someon do comaprison in that way?
You could try something like @OCA Gsonic. It's free, easy to use and generates FIR filters that can be loaded directly into Roon, which is what I've done. I've had good results with it, although don't have a miniDSP shd/DIRAC for comparison. If subs aren't involved, Gsonic might be all you need.
Edit: You can also add a delay to a speaker in Roon using the speaker setup feature.
I'm really happy with the denafrips arce streamer, I wouldn't want to lose anything by switching to the minidsp shd studio...But corner do magic, its boss against open space on the right I'm also thinking of making a panel that illustrates a wall to create a reflection, but it probably wouldn't be a huge success.
Now i have KLH model 5, since I'm thinking about buying high-performance speakers, I came across the Atlantis lab 23pro, where the bass reflex tube can be adjusted...which would probably be very effective...
