luckyguliver
- Joined
- Nov 24, 2022
- Messages
- 6
- Likes
- 2
In this case I wanted to use it as a pre amp - streamer - dac.What would you use it for then?
What if you don't use Dirac?
What did you do with Dirac and why wasn't it impressive?I think it was a bit misleading the way I wrote what I need it for as I meant internal SHD Dac not external Dac. I want to keep things as simple as possible even though it’s not always possible. I tend to change my gear pretty often so SHD will be used in many different configurations and for different purposes. I also must say I played with Dirac function already but the result wasn’t very impressive. It’s early days so I am to bothered
Soundstage is more focused towards the center of the room but is "painted with thinner lines" so to speak. Overall sound seams to be "strained" not as open as without use of Dirac.What did you do with Dirac and why wasn't it impressive?
I’ve had the same exact experience. I’ve been listening for the last week and I keep going back to unprocessed signal. The three dimensionality of the images disappears with dirac on. It goes from three dimensional “I’m there” feeling to a two-dimensional “on a screen” feeling.Soundstage is more focused towards the center of the room but is "painted with thinner lines" so to speak. Overall sound seams to be "strained" not as open as without use of Dirac.
I also wonder how can I add sub to the process of calibration. When I set it up initially I did it only for two speakers but now I want to add sub but I can't find way to do that.
No expert here, but if you are considering Lyngdorf you may also have a look at the Trinnov, its out of my budget but I have seen many intresting reviews and comments.I will do a couple of more tests as well. It all goes very slowly as I've got loads other things going on. If I will be not very impressed than I switch to Lyngdorf and see what they have to offer in terms of room acoustic correction.
If you try Lyngdorf please let me know your thoughts.I will do a couple of more tests as well. It all goes very slowly as I've got loads other things going on. If I will be not very impressed than I switch to Lyngdorf and see what they have to offer in terms of room acoustic correction.
Can you describe your setup? I know Dirac quite well but never experienced going from 3D to 2D. I have both experienced benefits and detrimental effects from using Dirac Live. Measuring correctly helps a lot and also the type of speakers seem to make a difference. I currently have active open baffle but even when they were passively filtered Dirac didn't do that much good.I’ve had the same exact experience. I’ve been listening for the last week and I keep going back to unprocessed signal. The three dimensionality of the images disappears with dirac on. It goes from three dimensional “I’m there” feeling to a two-dimensional “on a screen” feeling.
I’m going to re measure with 90-degree cal file and vertically placed mic and exactly measure each mic spot to make a sphere of 50cm diameter around my listening position and see if that improves things. But atm I’m not holding my breath.
My set-up:Can you describe your setup? I know Dirac quite well but never experienced going from 3D to 2D. I have both experienced benefits and detrimental effects from using Dirac Live. Measuring correctly helps a lot and also the type of speakers seem to make a difference. I currently have active open baffle but even when they were passively filtered Dirac didn't do that much good.
I have had very good result with "boxed" speakers. In the case of the Dutch&Dutch 8C it didn't do much good but also no detrimental effects.
Regarding the measurements, the first measurement should be exactly at the MLP, most often exactly in the middle. Even a few cm off can give odd effects as it can change the balance and timing.
Hope the new measurements work out well and let us know.
Το τρίγωνο πρέπει να είναι ισόπλευροΗ ρύθμισή μου:
Sitting slightly nearfield from the tip of the equilateral triangle sounds best in my room to both my ears and my measurement microphone.Το τρίγωνο πρέπει να είναι ισόπλευρο
A suggestion and a comment as follows: If you haven't already, try pulling back your chair so thatMy set-up:
My hi-fi:
I placed the mic horizontally with the 0 degree at the exact center of listening position accurate to the millimeter:
I will do a re-measure and see if I get better results. But at the moment Dirac is destroying my sound completely.
Nice setup (like the books and the Mr. T cushion). One suggestion and a comment: (1) If you haven't already, suggest you pull back your listening chair so that you have a true equalateral triangle. Suggest you run Dirac with the mic at the vertex of the equalateral triangle. Take just one Dirac measurement to start and then save and upload that single measurement sweep to miniDSP. Then take a frequency response measurement with REW. You should have an absolutely FLAT response with a single measurement if you don't move the mic. If your frequency response is not flat, there is likely a problem that may be sampling related. I'd have this occur frequently when using a uMik-2 and Windows. It would manifest as a steep taper off at high frequencies. I ended up giving up trying to run at 96khz and going to a uMik-1 and 48khz sampling rate. Dirac should definitely not diminish your sound stage in a nice room like yours; if anything, just the opposite. Now the comment (2): it's not an apples to apples comparison if you're just using the remote to toggle on/off Dirac with your remote without compensating for the volume difference that Dirac takes away. This will negatively effect soundstage perception because we tend to perceive louder signals more favorably (up to a point).My set-up:
My hi-fi:
So you suggest measuring from tip of equilateral triangle even if that isn't the ideal listening position in my room? Okay, I will try it, along with running an REW sweep directly after to see if I get a flat response.A suggestion and a comment as follows: If you haven't already, try pulling back your chair so that
If you’re after volume control and dirac/DSP then yeah, don’t see why it won’t work great. I have a good room and my speakers measure so well unprocessed at my listening position that adding dirac seems superfluous. It seems to be over correcting for a problem that isn’t there, and takes a bit of headroom off my amp. But for your actives it could be awesome. Not sure if all the ins and out of an active system though.I'd consider using that unit as a pre amp with active speakers. With the room correction, would make a great 2.1 system, unless I'm missing some reason otherwise. This appears a much more user friendly unit from MiniDSP for not non tech types like me.
Thoughts/opinions on the idea?
