Minidsp SHD Review Updated (DSP, DAC & Streamer)
All inputs both digital and analog only support two channels. So I kind of stand by my statement this is a two channel (i.e. stereo) device, though you can split and mix those two channels four ways.
You're correct. For some reason I thought it did accept 4 channel inputs over digital due to the routing matrix showing 4 channels, but it only accepts stereo inputs which can be sent to 4 channel output.
If you want to connect the TV, Blu-ray player and Chromecast, there are a few potential solutions, all with their own drawbacks.
1. Get an optical switcher - this adds another box/remote
2. Attach the blu-ray player and chromecast to the TV (the normal chromecast, not CCA). Then you stream cast to the chromecast attached to the TV and the optical out of the TV to the SHD.
3. Attach blu-ray player to TV, but for CCA you can use the analog out to attach to analog in of the SHD. However, you are not doing D/A and A/D conversion.
4. Get an optical to coaxial adaptor for the CCA, again adds another box to the solution.
I use solution #2 as my TV and Firestick have chromecast functionality built in.
With respect to 12V trigger, that is a drawback indeed that I am also frustrated with. On minidsp forums or other websites, some people have suggested taking the USB host connection of the SHD and re-wiring the other end to a 3.5mm cable. If you amp can get triggered with 5V this may be enough. However, I think the USB host connection is always 'live' when the minidsp is powered on so this solution may not work. I have yet to figure out how to trigger my amp with the minidsp.
Thanks for your answer.
I might choose a switcher... I don't want to use the TV each time, especially for the CCA and the BR player is used to play CDs as well.
The 12V trigger is a huge downside, I know it will get obnoxious over time...
Correct on the final point. USB and the entire digital side of the SHD is powered on during standby (you can even start streaming a song from volumio). This is why the USB power trigger idea doesn’t work, and also why the coaxial digital output also won’t work with a product like the BobWire DAT1 which is made to produce a 12v trigger based on whether there’s a DAC clock lock (on the SHD the output clock is always active). The DAT1 also offers an analog signal detection trigger which is less elegant than a true power trigger function, but for people without that feature on their power amps at least it’s an option.
Yeah this fully fixed my issues as well. How much of the issues are down to the nano pi I wonder? Would be awesome if mini dsp could offer a pi upgrade. I figure it would be fairly easy to swap out a pi for another within the unit, so long as they supply the appropriate software.
I don't think it is a easy swap. The form factor and pins of nanopi are totally different. They directly attach to the minidsp board through pins to get power and send audio out. I looked at that option and found that the nanopi neo4 is different from the neo2. No idea how nanopi naming works.
The neo3 was released a couple of months back with rockchip processor instead of allwinner, also with USBC power connector on different side. I was expecting an upgrade to allwinner h6 without change of port locations. The USBC power connector has to be removed from the board to fit to mini-dsp case too. Moreover no guarantee that volumio will work on a different chip. I think we are stuck with external RPi or what is within unless friendlyelec releases a compatible replacement.
Had a close look at the Neo2 vs Neo3 boards. Neo2 is 40 X 40mm whereas Neo3 is 48 X 48mm. Also Neo3 does not have audio pin out. So even if we have volumio supporting Neo3, it cannot physically fit in the neo2 location of minidsp or send audio to minidsp (I am assuming minidsp use the audio output pins of neo2.. Please correct me if wrong).
Edit: Added comparison of Neo2 vs Neo2
The neo3 was released a couple of months back with rockchip processor instead of allwinner, also with USBC power connector on different side. I was expecting an upgrade to allwinner h6 without change of port locations. The USBC power connector has to be removed from the board to fit to minidsp case too. Moreover no guarantee that volumio will work on a different chip. I think we are stuck with external RPi or what is within unless friendlyelec releases a compatible replacement.
Thanks for looking into that. What a drag that its not simply plug in the upgraded nano. Ah well my rpi works perfectly and as noted above, with the USB never turning off the external rpi never loses connection (which mine used to with my old su8 dac). People might prefer it to switch off but I way prefer it stay live. Also I much prefer the moode interface than the version of Volumio that runs in the SHD. Happy with my decision and it just sounds so much better with Dirac. Next stop, subs.
SHD is only a two channel device. It won't support AVR right/left/sub(s) preouts. And if you route LFE to mains on the AVR and use only r/l preouts to the SHD, you don't get correct LFE/bass management implementation.
In addition to the aforementioned 26ms delay issue to the remaining AVR channels.
Why won't the LFE information be correct if it is being re-routed to the L/R channels? Yes the SHD will introduce delay, but that shouldn't be too hard to account for in the AVR.
I am actually trying this out with a client of mine, so we'll see if it works out in the end. I'm not sure if something like this has been done before but I honestly don't see why it wouldn't work. And if the LFE channel is really so important than you could just run a 2x4HD parallel to the SHD and feed the 2x4HD with LFE. Or use two SHD's if you've got the money for it.
No I had it powered up using the power supply. I didn't realise it would work powered by USB...
Actually, not recommended. CCA needs to draw up to 1A, but the I think the USB port can only supply 500mA.
1) All LFE above SHD sub crossover will run through the mains, not the subs as intended. And this LFE will be +10dB hotter and will need extra headroom on the mains (compound that issue if using the SHD Dirac too).
2) LFE important, absolutely if you are aiming for accurate reproduction of a movie. If not, well that's not a very high standard to aim for for paying clients imo.
3) Some AVR's are limited in delay, in this case 26ms PLUS that needed without the SHD in the chain
4) Another miniDSP either HD or SHD is not really helpful, complicated to setup and use, and an unnecessary expense. Now an 2x4 miniDSP setup for proper multisub integration, for use on both the music and the HT sides, is a wonderful thing (that' s how I have mine setup).
A switcher is all it takes to eliminate ALL of the issues created trying to run the AVR through the SHD ADC :cool:. Good luck.
For stereo use, the SHD is going to be used with digital inputs, so no need for the AV Processor at all (thank God).
To your first point, L/R + redirected LFE will go into the L/R inputs on the SHD. Now the SHD will be used as the crossover between the mains and the subs. The mains in this case are plenty stout and could play down to 30Hz if needed, but they will be high passed. The subs will be low passed. The LFE information will be going to the subs and the mains but with the crossover this shouldn't be an issue. And with independent gains, equalization and a DIRAC target curve, even if the LFE comes in hot, that can be completely accounted for and dialed in.
For your second point, bass is important, and given the room and placement constraints, I need all the tools available to dial in the bass. The SHD gives me those tools, while the AVR ties my hands behind my back. I've already ran measurements and the response is far from perfect. A MiniDSP 2x4 gives you control over the subs, but I want that same level of control over the mains as well.
Third point, well the receiver has enough enough delay to account for the 26ms of the SHD plus how the speakers are configured in the room. A 2x4 would introduce delay as well, so that is not an issue unique to the SHD.
The points you bring up I'll definitely keep my eye on, but I still think this approach will provide better bass (LFE) to the user at the end of the day. And better sound from the mains, thanks to DIRAC. I've already measured inside this particular room and it has its fair share of issues.
Now I still have the option of regulating the SHD purely for bass management on the LFE channel when use in HT just as you do with the 2x4. While also retaining a stereo 2.2 setup using only the SHD for digital inputs. SHD is an extremely flexible product so I have options.
Oh my...way more than enough for a whole 'nother HT setup thread elsewhere. Better to move back to solo SHD discussion here.
Plus customs handling fees and the time and bother...saving penies and too much trouble in the end maybe..Still envious of much cheaper it is in the US.
I know Dirac is sort of the whole point, but wish they made this with an OpenDrc platform, and three channels so you could roll your own, and cheaper too, no Dirac licensing..Waiting for Okto to rock their boat :)
Is Okto planning to support OpenDrc? That would be something :-)
I agree, but someone did ask if they could use an SHD in HT.
And I was able to successfully integrate the SHD with an AVR over the weekend. For stereo use the SHD does it's magic with DIRAC, and in HT I was able to time align all the channels using an acoustic timing reference, accounting for the added delay of the SHD. The AVR's room correction is working just fine with all the channels properly level matched.
So an SHD can be used in HT with incredible results. Having the SHD is very important as the independent delays and crossovers are much better than what is found on the AVR. This is necessary to get the best bass possible between the mains and multiple subs.
The best solution is buying a Datasat RS20i. That has all the functionality of an SHD and then some for proper HT. But that costs $20,000.
For any owners or owners to be.. one thing I would highly recommend is a programmable universal remote. The included remote works but I don't care for it. I have the version 1 of the remote which has
-a source button that cycles through all of the inputs (no discrete buttons to directly select a source)
-4 presets
-Dirac on/off
-volume up/down
-mute
The version 2 remote remote has a different layout and adds power on/off and skip forward/back but is still lacking discrete inputs. I hate scrolling inputs. One thing I was surprised is the skip forward/back and play/pause work while using roon.
A while back they provided remote codes to program your own remote. To my surprise they provided ir codes for discrete inputs. Programming a universal remote with discrete codes with meaningful names such as listen to music, watch tv etc makes it much more family friendly to use. There IR codes are in the same location as the firmware updates.
For those that need long hex codes (for example I use URC/Universal Remote Control) you may need a different format than Minidsp provides. I have attached these here a member on Remote Central kindly converted for me. In case it helps anyone.
Didnt read here all completely, but what is the difference to the smaller much cheaper miniDSP SHD Studio All Digital with Dirac Live 3.x ?
850$
850$
Studio does not have a dac or analog inputs
Though spdif can work with aes. It doesn't always work though.
Can you please point me where is that "core part" that the manufacturer thinks the device is designed for? Digital out is an auxiliary spec as far as I can see.
So where is the Trigger out for the power amplifier?
- Rich
