- Joined
- Jul 12, 2024
- Messages
- 3,291
- Likes
- 5,156
MiniDSP just released an RCA to SPDIF coax and Toslink analog to digital converter.
Assuming it tests close to specs, it's an affordable way to add another analog input to a Flex or other DAC/Pre-amp.
They included a useful feature for Flex users. It daisy-chains the power cable from the Flex so you don't need a second adapter.
| Description | |
| ADC Chipset | ESS ES9821Q |
| ADC resolution/Sample rate | 24 bit - 48/96/192kHz selectable via front panel dip switches |
| Digital Audio Output Connectivity | 1 x SPDIF on RCA connector, 1 x OPTICAL on Toslink connector |
| Input/Output configuration | 2 x channel analog in (Unbalanced), 2 x channel digital out |
| Frequency response | 20 Hz – 20 kHz ± 0.1 dB |
| Maximum analog input | 2Vrms |
| Input impedance | 100kΩ |
| Signal to Noise Ratio (SNR) | 118dB(A) |
| THD+N @1kHz | -114dB(0.0002%) |
| Crosstalk | -130dB |
| Power Supply | Included external switching PSU 12V/1.6A (US/UK/EU/AU plugs) Link cable to power PocketADC and your Flex with a single power supply |
| Power Consumption | 2 W (idle) |
| Dimensions | 13 x 40 x 62 mm |
