Daltong
- Joined
- Mar 9, 2022
- Messages
- 47
- Likes
- 5
Okay, so I was using that OpenDRC-DI thing as equalizer and kind of annoyed by the sound. Something not quite right (qudelix sounded better, if not for the constant clicking it gives me on Linux and level adjustment weirdness that is part of their brand of DSP)
I decided to measure it using RMAA. TOSLINK from PC to MiniDSP, then TOSLINK from MiniDSP to ESI U24 XL on another PC.
First I of course measured just my sound card (TOSLINK from PC to another PC with ESI U24 XL )
Here's what it looks like PC(source) to ESI U24
There are also two THD graphs that don't get included in the report, also don't look too terrible
not too bad, it seems
Now let's see what OpenDRC does (I did mind the fact that OpenDRC always outputs 48 khz, tired recording both 16 and 24 bit, same result
NO EQUALIZATION WAS APPLIED AND OPENDRC WAS FULLY FACTORY-RESET BEFORE MEASUREMENT (all presets cleared)
The respective THD graphs are also completely out of whack pardon my french
ouch!
ouch ouch ouch
Oddly, report for OpenDRC measurement still states
Since it was all TOSLINK from source to recording soundcard, and since original soundcard recording isn't too terrible, I have to ask... what's going on here?
is there some kind of measurement misconfig I am woefully doing, or is my OpenDRC-DI really doing quite not too little frequency skew of its own and also adding suspicious amount of distortion?
And why with additional THD graphs being that ummmm... weird overall THD measurement in the report still claims decent distortion values?
Am I just being needlessly paranoid ?
Left | Right | |
From 20 Hz to 20 kHz, dB | -0.00, +0.00 | -0.00, +0.00 |
From 40 Hz to 15 kHz, dB | -0.00, +0.00 | -0.00, +0.00 |
Left | Right | |
From 20 Hz to 20 kHz, dB | -3.24, +1.53 | -3.24, +1.53 |
From 40 Hz to 15 kHz, dB | -1.95, +1.53 | -1.95, +1.53 |
ouch!
ouch ouch ouch
THD, % | 0.00054 | Excellent |
THD + Noise, dB (A) | -89.0 | Good |
