Digital version only has digital outputs. Analogue versions only have analogue outputs.Can you not mix/match a and d outputs? If not then yes a cheap dac should be plenty fine.
Right - but only analogue outputs. You can't send analogue to sub and digital to speakers.MiniDSP FLEX 8 has 2 x digital inputs and 8 x analog outputs.
Can someone post a picture of the power supply that came with the flex (original flex, not flex 8). I lost mine and would like to know what it looks like to know what to look for... or where can I get a replacement? Thanks
Have a look at the thread here for some wireless options:Has anyone ever tried to unse one Flex unit for several rooms/ setups? In theory one could measure each room individually and then create corresponding filter sets and load it to the flex, right?
How would I be able to stream the corrected digital toslink or coaxial signal wirelessly to other rooms? I dont want to lay cables around my place. Any cool ideas?
The flex 8 is supposed to get WISA certification soon which is a wireless audio standardHas anyone ever tried to unse one Flex unit for several rooms/ setups? In theory one could measure each room individually and then create corresponding filter sets and load it to the flex, right?
Wow, thats really nice. Here some copy pasta from minidsp:The flex 8 is supposed to get WISA certification soon which is a wireless audio standard
Bi amping (or tri amping) speakers, with active crossoversWhy have 8 WiSa outputs with only stereo input? Who needs 6 subs?
But the speaker already have all the electronics behind the WiSa receiver. It only needs one channel.Bi amping (or tri amping) speakers, with active crossovers
Sorry missed the wisa part of the question. No, can‘t think of anythingBut the speaker already have all the electronics behind the WiSa receiver. It only needs one channel.
There aren’t really DIY solutions yet, nor stand-alone receivers.
Well, B&O has one for about $€£ 200. Obviously made for the B&O ecosystem. You can also buy some naked PCBs that can do it, but those are eval boards, and priced accordingly.Sorry missed the wisa part of the question. No, can‘t think of anything
hm, DBA Users may need it. I have 4 Subs and already thought about adding 4 more...Why have 8 WiSa outputs with only stereo input? Who needs 6 subs?
But you don’t need then all on discrete channels, do you?hm, DBA Users may need it. I have 4 Subs and already thought about adding 4 more...
Well, for multisubpurposes it may be helpful and also for not perfectly placed dba subs (separate delays can solve some issues). Also playing with MSO requires discrete outputs.But you don’t need then all on discrete channels, do you?
