First of its kind to land in the blue "excellent" category!
Yes. Dirac is automated. You can do similar work manually with the filters in this box. In addition, you can also route low frequency to subs. Or implement an active speaker system.I'm sorry to ask, but can someone please explain the DSP functionality to me and why I would need it? Does it do similar things as Dirac?
Well, not so fast. The thing still only has 16-bit equivalent performance despite the 110+ SINAD, and word on the street is the second pair of channels is significantly worse. It almost looks like companies also know that Amir only measures the first set of channelsIt's great to see some companies focusing on performance with their new products and I'd suggest it's partly to do with the testing done here.
Do you know Amir’s FFT window settings? I’m thinking of doing my own measurements later today.Well, not so fast. The thing still only has 16-bit equivalent performance despite the 110+ SINAD, and word on the street is the second pair of channels is significantly worse. It almost looks like companies also know that Amir only measures the first set of channels
No idea. You should be able to use the ADC to measure the 2nd DAC output I guess. ADC is pretty goodDo you know Amir’s FFT window settings? I’m thinking of doing my own measurements later today.
I have an ADC already with like 115dB SINAD. Should be more than enough to show if the channels are identical.No idea. You should be able to use the ADC to measure the 2nd DAC output I guess. ADC is pretty good
And don't forget that Dirac is more than just a bunch of PEQ's. It also tries to optimize the impulse response, so time aligns your speaker units. But unless you have a coaxial system, this only works well on the listening position though. I've also had some interesting results with sidewall reflections on my desk setup. There, it is really evident that it does much more than frequency response correction!It is though considerably quicker and easier than what can be done more manually using REW to define PEQ filters via the Flex.
The way I see it:For purposes of some functionality, is this basically the minidsp SHD without the streamer (if you add the Dirac license; the SHD includes the Dirac)? Whereas the minidsp SHD studio is the SHD without the preamp/analog i/o?
As to expanded functionality, is it essentially an upgraded version of miniDSP 2x4HD that provides Dirac (as an option)?
I understand it has additional uses beyond what the SHD/Studio offer (thus my question as to how it relates to the 2x4) but from a basic end-users perspective I'm looking for clarity on its use. I did read the web page and elsewhere. A few comments on other forums also suggest a bit of confusion as to where this product fits vs minidsp's similar offerings?
It can So if you're willing to spend some time you can do lots of fun stuff. Mind you, Dirac only used like 1k taps as well, but also employs IIR filters. It's just about being smart about it.Also, the Flex without Dirac Live has the capability to apply FIR filters to manually make some phase adjustments. Although the total number of taps limits the frequency range over which this can meaningfully be done.
