Genstruktur
Hi,
I bought a Mindsp flex analog unbalanced a while ago in an attempt to replace an analog PEQ that i have and was happy with. But I thought that Flex would be easier to set up precisely.
I have connected Flex between receiver pre out and power amplifier. I understand that it may not be the primary area of use since most people use Flex as a preamp and connect various sources to it. I have still read some who use it this way and the manual specifies that you can connect it to subwoofer pre out for example.
I have installed the latest software on Flex. At first I just thought to see how it "sounded" without any filters or anything activated in Flex. So I connected it via rca from the receiver's pre out and into power amplifier. I had Flex main volume at 0 and Flex in/out at 0 and analog source in Flex at 0.
Now to the problem. At lower volumes it sounded okay but not that great and certainly not like without Flex. When I started to raise the volume at my receiver, to what i play as the loudest, it started to distort. And in the Flex device console i see that i am close to 0 dBFS on the input/output.
I tried many different variations but I can't get it to sound good with Flex in the signal path. At least if I want to keep Unity gain through it. I tried raising/lowering the analog source in Flex, raising/lowering the input/output in Flex and raising/lowering the receiver main volume to try to keep Unity gain but the result was the same. It sounds okay, not good, at lower volumes and it distorts at higher volumes.
I have a Rotel RB 1582mkII with input sensitivity 1.9V, so I think Flex should be able to drive it to max output with its 2.0V max for the outputs.
I will try again today with Flex but as it is now it is unfortunately not possible to have Flex in the signal path. Is there anybody who uses Flex like my setup and got it to work? Any suggestions?
