I chose the cables based on MiniDSP recommendations:
support.minidsp.com
support.minidsp.com
This is how I understood it should be done, with a dual mono cable, as Flex is outputting mono signals anyway. I'm by no means no expert, maybe I got it wrong. It worked for me, though.
Flex Balanced connectivity: Which TRS to RCA cable should I use?
The Flex balanced is balanced in/out. If you'd like to use an unbalanced amplifier (e.g. Powered subwoofer) downstream of the Flex series, here is the recommended TRS to RCA cable to minimize detrimental effect on the audio quality. Note how...
I'm using a TRS to RCA stereo cable and not getting any signal on my subwoofer. Why is that?
You've received your Flex TRS unit and you're excited to connect it up to your system for a 2.1 setup. You didn't purchase miniDSP's TRS cable but instead used that TRS to RCA stereo cable. It's most likely looking like this. You connect e...
