I think that it will give me much more control in the BASS area, as these are homebuilt subs and I do not have all the cool features of newer active subs.With your amps measuring that clean, Dirac might not add much.
The two attached plots show distortion for the left Karat 300 with both subs operating and the right Karat 300 with both subs operating. The graphs include the fundamental, the third harmonic, and total harmonic distortion for easy reading.
Honestly it sounds good in the room. My wife found out what I spent and didn’t even blink. She actually sat down and went through a bunch of songs and enjoyed it, and she usually has a better ear than I do, so I use her as a sanity check when I’m dialing things in. She gave me a hard time for most of the system while I was building it, but this time she didn’t.How does it sound? Those fr graphs look a little rough to my eye.
I dropped the Denon x4800h and just use the htx as an AV pre-amp.
Oh excellent.Honestly it sounds good in the room.
Honestly when I have some time I’m probably going to sweep each speaker individually and do a bit of manual EQ. I do want to tighten the timing and integration of everything together.Oh excellent.
So no DSP yet? Audyssey is good. I like Dirac better but only by a small amount. That will get it even better sounding.
Oh wow. I think you will saved future me ALOT of time. Thank you so much. I initially purchased a DDRC 24 but realized after I ordered that was just a 2x4 HD in disguise so I upgraded to Flex HTx through customer support e-mail so my purchased never properly got registered. I am emailing them to tie my serial number so I can purchase the integration.Yes. $30 for the REW integration is worth it if still in your budget.
Does this mean you've set the AVR to have only 5.0 and mix the LFE in? Not sure why you'd do this, since LFE is definitionally mono -- why not use 5.1 on the AVR and then manage the LFE mix on the HTx?With the AVR operating in 5.0 and no LFE channel active, LFE content is folded into the front left and right preouts.
AutoEQ is a solid feature. Most of its suggestions centered around the crossover region, which wasn’t where I wanted changes, so I went back to what I’m more comfortable with: manual sweeps. I only made a couple mild voicing tweaks on the right side to better match the left.Does this mean you've set the AVR to have only 5.0 and mix the LFE in? Not sure why you'd do this, since LFE is definitionally mono -- why not use 5.1 on the AVR and then manage the LFE mix on the HTx?
(Just curious! If you're happy with the results I guess this is working for you.)
Yeah, the big upside to your approach is having a true discrete LFE channel, which definitely gives you more flexibility if you want to shape the 0.1 track separately for movies.But the use of the word "LFE" implies source content that already has a .1 LFE channel. This is what I would do if I was keeping the AVR (which I would not, but that's just me!)
- Set L/C/R/Ls/Rs etc to "full range" on the AVR so it doesn't do bass management.
- For content with .1 LFE channel already: get that into the HTx on a dedicated input, and then you can decide what to do with that in terms of your routing/sub setup/any other filtering/delays etc.
- For the full-range signal for the rest of the channels, you can use the bass management in the HTx to route to your subs or not, as you wish.
This way, you preserve the "rumble" or sub-bass in the LFE channel in a dedicated unmixed input.
This is cleaner than your AVR mixing the LFE into the 5.0 and then you splitting it out again.
In other words: bass management is not the same as the dedicated LFE channel in x.1 content.
All just my opinions, I offer for your consideration or dismissal.
LFE is recorded 10db down, so per the bass management tab in the MiniDSP manual, you need to account for this, for example by setting all other channels down 10db.When I run Dirac Live it calibrates 5.1 channels including the LFE.
How do I then measure that with REW? The only way to get a subwoofer measurement is by adding L+R in the matrix mixer, or do I add it in the channel router?
And what's the +10db LFE thing?
If you are running REW in your connected PC or Mac over USB to the HTx, you need to keep in mind that the USB interface flips the LFE and Center Channel relative to an HDMI interface. You also need to configure your PC/Mac sound output for 5.1 channels.When I run Dirac Live it calibrates 5.1 channels including the LFE.
Putting the other channels down 10db does eat into potential sinad. But it also reduces chance of digital clipping if combining multiple channels (eg left and left surround)LFE is recorded 10db down, so per the bass management tab in the MiniDSP manual, you need to account for this, for example by setting all other channels down 10db.
Just remember to offset than before running Dirac (you can use the output tab to do so).
It is all in the manual. Being a man, I didn't bother reading it properly so initially had Dirac boosting my bass considerably to get a sound I liked.
I am not sure what you mean regarding REW, so will let an REW expert answer for you.
Remember that you might also need to attenuate channels for any mixing you might do from 7.1 to 5.1.
Are you using an HTx and if so, have you tried to work this a different way? Analogue gain on the sub?Putting the other channels down 10db does eat into potential sinad. But it also reduces chance of digital clipping if combining multiple channels (eg left and left surround)
