miniDSP Flex HT Help needed (HDMI)
jost96
Hello from Germany,
I've got a FLEX HT. I wanted to use it for my active controlled 3way 5.1 setup.
So far so good. I got it with the DIRAC Full license.
Actual I used it on a TCL TV (No Multichannel) now I've got a Nvidia Shield. Here works nearly everything. It makes the stereo 5.1 Upmix which works good. I see the 6channels in the HDMI sector of the minidsp software. I use Tivimate for streaming. Here everything sounds good. Spotify also works. If I use Youtube I get a unlistenable sound. Permanent crackling.
Is here some way to fix this?
Is there any other good option beside the Apple TV?
If I connect my laptop to hdmi and set 7.1 on it I also get every channel and a clear sound!
I tested it also with a apple TV. Here I got the same problem.
