We just published a new tech blog that provides an overview of miniDSP's Device Console, this covers the 2x4 and 2x8 architectures: Overview of miniDSP Device Console
The reason is, if you wanted to sum inputs from the two different channles you could mix them at independent levels, see:Very nice, however i miss an explanation for the outputlevel adjustment in the output channel just below the upper channel designation. Compared to the gain, why is there a 2nd level adjuster in minidsp?
3. Delay/Gain on the Inputs is active via default. I've had that completely destroy imaging on pairs of speakers when have forgotten to turn it off. And, apparently is has to be turned off every time the Device Console is started.
I don't understand this point? Surely you set your delay/gain at what you need and leave it at that? There is no need to turn it off if you have delay/gain set at 0.
According to their online manual it's not possible to change this on the input side for DiracIt appears to me that Dirac sets a Delay/Gain on the inputs (unless you disable this option) in the miniDSP control panel and after it does so I've not figured out how to set it back to zero manually in the control panel. The screen shot below shows a 0.04 ms delay set on Dirac 1 and 0.3 dB gain set on Dirac 2. I didn't set these, so Dirac Live must have done it.
I don't ever want any Delay/Gain set on miniDSP Input side. However, delay and gain adjustments on the Output side when using two main speakers and two subs are routinely set by me manually.
What if I don't use DIRAC, is it possible to increase the delay?According to their online manual it's not possible to change this on the input side for Dirac
Flex DL manual
