MiniDSP just sent a newsletter email detailing a fancier Umik-2 ($195) and Umik-X ($200). Hadn't seen it shared here yet.
The Umik-2 has a larger capsule with lower noise and distortion, which could make it better for measuring distortion and at high SPLs. It also supports more sample rates from 44kHz to 192 kHz. Could be handy as sometimes I come across sample rate issues with DSP speakers. It also, mercifully, uses USB-C instead of the godawful mini-USB I always feel is about to break.
That said, I wish MiniDSP provided a linearity graph. No clue how flat it actually is. A CSL-calibrated Umik-1 is still cheaper.
It also has a lower rated max SPL at 125dB vs 133dB, which is a bit disappointing as I was hoping it'd be able to handle higher SPLs. One issue I would often run into when doing quasi-anechoic spins is that I couldn't measure the woofer and/or port at the same SPL as my far-field measurement. It's part of the reason I typically do my speaker measurements at low 75 dB/1m; I have enough headroom to not change the volume when I place the mic against the low frequency units.
The Umik-X uses multiple MEMS microphones for multichannel measurements and seems to be primarily intended for quick and consistent room correction measurements.
Relatedly, REW now has a one-time Pro upgrade($99) that offers multi-channel measurements to start, with more to come later.
