Mini line array - 3D printed waveguide for high frequency dispersion
Bluesnoz
Hi, first post here so please be gentle :)
I'm a semi-retired scientist who likes to experiment and has built, used and managed small church PA systems in the past. I've been wanting to try and build a portable mini sub and column speaker "stick" PA for a while. After a little research I saw some Faital Pro 3FE25 16 ohm 3" speakers on sale and thought they would be ideal (half price!). I've built 2 x 4 speaker top boxes and a 12" sub. I wanted to achieve a Bose-L1-like 180 dispersion, and after reading about the "shading" technique to address high frequency comb filtering in line arrays.... I attempted a different solution using a series of 3D printed waveguides.
After some educated guesswork and a series of rudimentary dispersion measurements, I'm reasonably happy with the outcome... although always a compromise, the polar plots show reasonably even dispersion from 3-12kHz (the best 8kHz shown here). To my ear the treble (>5kHz) really wraps around all the way to 180 degrees which is what I was looking for. As a musician and PA guy I like to bring a minimum of gear (no separate foldback) and stand to the side of the PA speaker, just like the Bose L1 concept.
Details for the 3D printed waveguides are up on Makerworld https://makerworld.com/en/models/3426865-speaker-high-frequency-sound-waveguide#profileId-3906127
As a newbie here my questions are:
1) I'm sure this had been done before, but I couldn't find any waveguide combinations like this with a quick search, does anyone have links to something similar?
2) Can anyone do some detailed computer modelling of the waveguides to try and improve the combination in the 4 speaker array?
Any comments welcome too!
Cheers
Good to see people actually doing sums, making things and measuring them on ASR, as opposed to armchair critics doing nothing bar making assertions!
Thanks! It is quite a discipline to stop and measure, but I definitely enjoy the building and measuring process. Plenty more data I can post too. Hoping to spark a constructive and inventive discussion.
Interesting. Reminds me of acoustic lens designs.
Yes I also remember these designs. My possibly flawed intuition on these lenses is that the fins slow the wave propagation and therefore act as a different "refractive index" similar to optical lenses. In my design I focused on creating reflective surfaces at the desired angles. But the interactions really need a cosmos model or similar to understand them in detail.... unfortunately not my forte.
I hope you will do more crazy (yet scientifically founded) experiments for us to observe.
Thanks for the encouragement. I'll try and share the rest of the polar plots so you can see the evolution.
I think that's basically correct. The fins present a longer path for the wave to travel, which ends up acting as a kind of delay. In your version you've created something like a hybrid lens/phase plug.
As promised, here is some more data describing the evolution of the design.
Firstly a comparison of the 4 bare speakers vs 4 x waveguide A:
You can see the waveguides have effectively spread the 8kHz signal but caused some beaming at 4kHz. Given the frequencies at or below 2kHz seem well distributed I changed the frequencies in subsequent test to focus from 2kHz - 12kHz. In the next set I repeat the 4x waveguide A with waveguides ABBA, replacing the inner two with a structure that allows more forward (0 degrees) level of 8kHz.
In the comparison above you can now see with the two central waveguides replaced, we indeed see more balanced projection of 8kHz so this is more balanced (red trace, lower vs upper plot). The beaming of 3kHz has also vanished (blue trace). [Please note the colours now correspond to different frequencies.] In hindsight I could have stopped here but I felt the 8kHz and 12kHz in the lower plot were still deflected to large angles slightly too much. Hence in the next set I tried replacing the central waveguides with type C where the central gap is widened by 2mm.
In the figure above (ACCA, upper plot) you can see the wider central gap of the waveguide C's is indeed balancing the dispersion of 12kHz slightly better than the ABBA configuration. Unfortunately the 8kHz dispersion (red, upper plot) now has a deficiency at 0 degrees and the beaming at 3kHz (blue trace ) has returned :rolleyes: . Therefore the final configuration (bottom plot) I tried a combination of all 3 waveguides A,B,C. Now in the lower plot the 8kHz dispersion (red) looks much better and the beaming at 3kHz (blue) is diminished. Unfortunately 12kHz is now developing clear lobes (black trace lower plot), at this point I felt without proper modelling my game of "whack-a-mole" had gone far enough! :rolleyes: In hindsight the ABBA configuration *looks* moderately more even in dispersion than ABCA...but to my ears the ABCA configuration *sounds* more uniform.
Keep in mind all plots are normalised so that every frequency set is scaled to read 90dB at 0 degrees (hence Relative dB), the actual frequency response measured with REW and a calibrated microphone reveals a broad peak around 2.6kHz in the final ABCA configuration with a fairly steep fall-off above 4kHz (see below), this is consistent over a range of listening positions roughly 0-20 degrees off axis.
Once you correct for this frequency response in DSP the speakers sound quite decent, certainly good enough for PA duties for my purposes. The dispersion at high frequencies is quite effective. It doesn't have the detail of a dedicated tweeter but it's not an unpleasant sound, albeit a little "soft".
Comments or questions most welcome.
Very interesting, how did you design the waveguides?
Great question. I have to confess it was mostly educated guesswork. I tried to read around the subject, phase plates, horns, line arrays etc then looked at the characteristic wavelengths to build an intuition of what’s going on. In addition you can clearly hear high frequency content reflecting off surfaces, even pieces of paper….and you can just hold a pencil in front of the dustcap and notice a pleasing drop in the native beamed frequencies. Finally when I read about shading high frequencies in line arrays to avoid comb filtering on this forum, I thought instead of achieving this electronically it could be done physically. There were more factors but in summary:
1) I wanted to build a small portable line array with 180 degree horizontal dispersion, but low vertical dispersion
2) I observed high frequencies appear to reflect off surfaces like light
3) the bare speakers had a harshness, improved by holding a pencil over the dustcap. High frequency beaming was very obvious.
4) line array shading is reported to produce less comb filtering..but this is mostly a high frequency effect
5) phase plugs/plates improve efficiency by limiting cancellation around the cone, disecting the area around the cone can achieve this
6) horn structures with increasing aperture improve coupling and efficiency
so really all these factors led to the inital design of waveplate A. It was educated intuition initially, but then I wanted to share the design and I felt it was only reasonable to back up the design claims with test data. That led in turn to the design evolution.
In my career I’ve always been a better experimentalist than modeller, calculations are not my strength. But to take this to the next level really needs some proper modelling, I know that. Still I’m listening to the setup as I type and it’s not bad….
Finally I should say some design elements are just about wrestling with Freecad to get a stable design. For instance in waveguide B and C there is a small central line that I doubt is necessary….but removing elements in a parametric model can break later stages….so I opted to make it very small rather than delete it. Pure laziness
Take a look at Boundary Lab, a simulation tool designed to simulate waveguides and complex enclosures
