MINI DSP setup?
I use a miniDSP OpenDRC-DI
Digital Sources -> switch -> OpenDRC-DI -> DAC
Digital in and out.
Manual settings or can use AcourateDRC automated room correction.
May have been discontinued, don't see it in their product list any more.
Curious, why do you want to insert a minidsp 2x4 or SHD instead of replacing your streamer with a Wiim pro as suggested above? They are the same price (cheaper than the shd) and the Wiim pro solves both the streaming and DSP problem in one and simplifies your system.
I’m not sure you can equate the DSP capabilities of the WIIM devices to MiniDSP. The latter has a considerably wider range of abilities, including the option to use Dirac.
@90sNintendoKid Another issue with CamillaDSP is that it does not have consistent latency.
Even if you used an interface with SPDIF input (which would ensure the Wiim and the interface were clock sync'd), you would have issues with integration if the interface was connected to a USB host running CamillaDSP. If you never restart or pause the USB host running CamillaDSP the delay seems constant, but if you ever restart or pause the delay changes.
If using CamillaDSP it is always best to process ALL channels through CamillaDSP.
Michael
