I am not recommending nothing, but only ask that you consider the MoFi SourcePoint888 ($5k/pr?).What speakers would folks recommend I try next in the $4k to $6k per pair range that they believe would provide enough difference that I will notice.
Erin's Corner (yt) states it this way:
Comparisons aside; I would not be surprised if you detect significant differences (possibly due to different design types) but I would not dare to pick which you would choose or prefer."This is my top recommendation for a speaker in the $5k/pair budget range. It checks every box I would want checked:
- good linearity
- great in-room tonality
- great distortion and compression
- low frequency extension down to 30Hz in-room
- easy to drive load
- excellent directivity (easy to EQ if desired)"
Wide H/V contour plots sold me on this coaxial design because solo listening is for... hermits!
