midrange peak, a problem in room acoustics
My guess given that the that peak is broad and very similar in both channels is that that's a reflection close to the mic, like from a chair. I've always gotten the best results by moving my listening chair out of the room when taking measurements.
I would guess reflection from behind, wall or the seat. Have this kind of peak from behind, that can be treated though.
I was going to suggest seat back/coffee table/ottoman that sort of thing in front of the mic.
All right, let's take a look.
We can rule out "speaker problem" first. This 1m measurement from your speaker shows that the midrange peak at 800Hz isn't there.
We can also rule out "toe in problem". The measurements do not change no matter where your speaker is aimed. But if we look at the manufacturer measurements, we see:
... that your speaker is radiating a lot of energy out the back at 800Hz. Keep this in mind for later. It also appears to be a very wide radiating speaker.
In the first set of measurements, all the measurements differ by a lot, but the 800Hz peak is present in all of them. The descriptions say that the physical location of the speaker was changed.
This is a comparison between Curve 1 and 5 in your first set of measurements. The position of the speaker relative to the right wall is unchanged at 0.92m. The only difference is that the green curve is 1.12m from the front wall, vs. the starting position of 0.92m.
What we see here: SBIR cancellations worsening at 60Hz and 170Hz, but the peak at 800Hz is virtually unchanged. Conclusion: my earlier concern that the speaker is radiating rearwards in the polar plot can be dismissed. It's not some kind of SBIR reinforcement.
So what if the speaker is moved closer to the right wall? This is a comparison of Curves 1 and 2. In the green measurement, the speaker was moved 20cm closer to the right wall. We can see the peak is still there, but it has improved a little.
To summarize what we have found, we now know that:
1. It's not a speaker problem.
2. It's not a toe-in problem.
3. Speaker positioning has minimal effect on that peak.
The remaining possibilities are:
4. Poor choice of listening position
5. Something local in the listening position causing a strong reflection that boosts 800Hz.
And indeed, if we look at the ETC, we can see:
There are 3 clusters of reflections at 1.6ms, 7ms, and 18ms within the Haas fusion zone (where the tonality of reflections is integrated with the direct sound by your brain). These clusters correspond to a path length difference between direct sound and reflection of 0.55m, 2.4m, and 6.2m respectively. That early reflection at 1.6ms is particularly strong, and I suspect this is the culprit.
What you need to do:
1. Make sure the 1.6ms reflection is real and not a measurement artefact. Examine your room for sources of nearby reflections. Please show us a photo of how you set up the microphone for this measurement, clearly showing the back wall and nearby furniture.
2. Starting at your current listening position, take measurements at 30cm increments moving closer and further from your speaker. Overlay the measurements and see what happens to that 800Hz peak.
Your room has three axes - front-to-back, side-to-side, and vertical. We have excluded the side-to-side axis through your measurements. The vertical axis is fixed. The only axis that remains is the front-to-back axis, which you have not measured yet.
I have a room acoustics problem, but I don't understand it enough to even be able to describe it well. So I guess I can at least give you the REW mdat files (attached zip folder contains two files). One shows what the speaker (only the R) is actually doing, umik-1 was 1m away and at tweeter height, and pointed at the tweeter. The second is made with the umik at the MLP pointed directly up (with that calibration file of course). Both of these without EQ, and no subs. In Denon's words -- Pure Direct mode. Same chirp, just different mic positions.
The problem is that big fat peak at around 815 Hz. It is very "hot" and in a range that's frequently used in music. Makes anything that plays in that range sound sharp, glassy, metallic, and if it's acoustic piano, piercing. In short, highly annoying. And everyone who has listed to this room hears it.
My other problem is that I'm a REW newbie and have just enough experience to understand that I don't know what I'm doing. And I don't know how to use this big complex tool to help me find the problem(s) in the room so that I can fix them. Any help appreciated.
For context, Denon AVR3800h driving Ascend Acoustic Sierra Towers V2 (not the ELX towers, sadly). The Ascend Acoustic URL tab "measurements" has the tower's published spinorama, so you can compare that with my mdat file from the attached zip folder.
The room is basically a sealed rectangular shoebox, roughly 13.7' x 20.5' x 7.9'. It's "well treated" with IIRC 15 absorber panels, 12 diffuser / absorber panels, and floor to ceiling tri-trap "bass traps" in all four corners. All from GIK Acoustics. There's three doors (closed during use), and three windows. Two outside walls (long wall to left of MLP, and short wall to front (behind TV). One side wall window and one door are "conveniently located" at first reflection points -- both have acoustic panel coverage. Ceiling has lots of absorption. Oh, yes, like most basement rooms this one has an HVAC duct running down the two outside walls. It's behind soffit of 1x4s, with 5/8" wall board (lots more lumber than just 16" on-center just because that's how the carpenter did it).
Speakers positions are basically about 1m (39 inches) from side walls and from the front wall. Puts them mostly but not entirely in front of the TV to minimize reflections off TV (ribbon tweeter has huge horizontal dispersion). The L/R pair are angled in slightly. I've played with positioning of the speakers and this too makes minimal difference to the 815 Hz peak.
I have pretty much eliminated the idea that this peak is coming from a resonance in the room. I've dragged my head all over that room, floor to ceiling, and can hear the effects of this peak everywhere, but can't locate the source. I've touched every light fixture, switch plate, electrical outlet, door, door knob, all the individual panels, all the windows, etc. during chirps but nothing changes the REW results. I've covered the couch (MLP) with our two biggest thickest blankets, then the TV (front and back), and nothing I can do seems to make much of a change, and what little change there is is probably because I'm in the sound field blocking / absorbing some sound. But that 815 Hz peak doesn't waver.
So I gave up on resonances, and started looking at reflection points that weren't already covered. Yesterday I went all in on this idea, and moved panels from other areas in the room (because I don't have any panels that aren't already installed), to systematically cover possible reflection points one at a time. Six in all. All that happened is that each step made the peak either a little taller or a little wider. Often they changed other frequencies making some better and some worse. But not at 815 Hz -- that peak only got progressively (a little) worse each test.
So I'm a little lost now. I'm pretty sure that REW has tools that would help me track this down better, but I don't know what they are or how to use them. Basically, I just don't know how to troubleshoot this problem. Please shove me in the right direction; it will be much appreciated.
You've gone to a lot of trouble, and expense, chasing this down - but I don't see any mention of Room Correction (REW).
Looking at your measurements, I think Room Correction can flatten this out, as it has done in my system.
I've attached the method I use. It's easy to do and gives great results.
Worth a try, IMHO.
I am sorry, I disagree with that advice. He needs to diagnose the issue first before attempting room correction at 800Hz. The wavelength of 800Hz is 43cm, you don't need to move much to change that pattern. The first step is to find a better position in the front-to-back axis, and then refine that by taking an MMM from that position. If the peak is still present, then removing it via EQ is a possible solution. Don't go around chopping high frequency peaks without thinking about it first.
Nice analysis, thanks for that.
I didn't measure the MLP moving forward and backward. True enough. I thought about it, but at the time I wasn't sure about the point of measuring behind that loveseat. That is, in front of the back, or behind the back. I'm sure the reflections in those two places must be quite different. So sorta like comparing apples and oranges? I should have done it just to see what it looked like.
Second way would be to move the seat with the microphone (forward and back) just to keep the loveseat more or less constant in the measurements. Would that help or hurt, or be in any way meaningful? IDK.
Third, I could just take the loveseat out of the room entirely. That might be interesting too.
Which one(s) would you like to see? Are then other alternatives that would tell you something that I haven't suggested yet?
As an aside, what frequencies does your ETC graph cover? I've been trying to get REW to show me something like that (over a small range of frequencies, like this peak) and can't figure out how to get it to this point -- where I can see the valid reflection timing.
Finally, that 1.6ms reflection is... interesting. That's about 0.5m more than the direct sound, yes? I'll string test that one first. I can't think of what it would be, but it's something.
How far is your microphone from back wall? And the seat? Any table in front of you?
Show us a picture of the microphone, your listening chair, and your back wall please. A picture of the front showing the loudspeakers would be good, too. Don't worry if it's messy, we've seen it all before. It will help us understand the acoustics of your room a bit better.
Why it matters: if you are measuring using a mini tripod perched on your seat, for sure that will affect the measurement. The microphone needs to be placed where your ears are going to be when you sit down. So you will need a boom tripod to obtain proper height. If you are unwilling to invest in that, an alternative is to duct tape your mic to a broom handle and do an MMM around the area where your head would be.
Some family obligations have come up; I won't be able to post more pix / measurements for a few days. Sorry for the delay.
