I have a room acoustics problem, but I don't understand it enough to even be able to describe it well. So I guess I can at least give you the REW mdat files (attached zip folder contains two files). One shows what the speaker (only the R) is actually doing, umik-1 was 1m away and at tweeter height, and pointed at the tweeter. The second is made with the umik at the MLP pointed directly up (with that calibration file of course). Both of these without EQ, and no subs. In Denon's words -- Pure Direct mode. Same chirp, just different mic positions.
The problem is that big fat peak at around 815 Hz. It is very "hot" and in a range that's frequently used in music. Makes anything that plays in that range sound sharp, glassy, metallic, and if it's acoustic piano, piercing. In short, highly annoying. And everyone who has listed to this room hears it.
My other problem is that I'm a REW newbie and have just enough experience to understand that I don't know what I'm doing. And I don't know how to use this big complex tool to help me find the problem(s) in the room so that I can fix them. Any help appreciated.
For context, Denon AVR3800h driving Ascend Acoustic Sierra Towers V2 (not the ELX towers, sadly). The Ascend Acoustic URL tab "measurements" has the tower's published spinorama, so you can compare that with my mdat file from the attached zip folder.
The room is basically a sealed rectangular shoebox, roughly 13.7' x 20.5' x 7.9'. It's "well treated" with IIRC 15 absorber panels, 12 diffuser / absorber panels, and floor to ceiling tri-trap "bass traps" in all four corners. All from GIK Acoustics. There's three doors (closed during use), and three windows. Two outside walls (long wall to left of MLP, and short wall to front (behind TV). One side wall window and one door are "conveniently located" at first reflection points -- both have acoustic panel coverage. Ceiling has lots of absorption. Oh, yes, like most basement rooms this one has an HVAC duct running down the two outside walls. It's behind soffit of 1x4s, with 5/8" wall board (lots more lumber than just 16" on-center just because that's how the carpenter did it).
Speakers positions are basically about 1m (39 inches) from side walls and from the front wall. Puts them mostly but not entirely in front of the TV to minimize reflections off TV (ribbon tweeter has huge horizontal dispersion). The L/R pair are angled in slightly. I've played with positioning of the speakers and this too makes minimal difference to the 815 Hz peak.
I have pretty much eliminated the idea that this peak is coming from a resonance in the room. I've dragged my head all over that room, floor to ceiling, and can hear the effects of this peak everywhere, but can't locate the source. I've touched every light fixture, switch plate, electrical outlet, door, door knob, all the individual panels, all the windows, etc. during chirps but nothing changes the REW results. I've covered the couch (MLP) with our two biggest thickest blankets, then the TV (front and back), and nothing I can do seems to make much of a change, and what little change there is is probably because I'm in the sound field blocking / absorbing some sound. But that 815 Hz peak doesn't waver.
So I gave up on resonances, and started looking at reflection points that weren't already covered. Yesterday I went all in on this idea, and moved panels from other areas in the room (because I don't have any panels that aren't already installed), to systematically cover possible reflection points one at a time. Six in all. All that happened is that each step made the peak either a little taller or a little wider. Often they changed other frequencies making some better and some worse. But not at 815 Hz -- that peak only got progressively (a little) worse each test.
So I'm a little lost now. I'm pretty sure that REW has tools that would help me track this down better, but I don't know what they are or how to use them. Basically, I just don't know how to troubleshoot this problem. Please shove me in the right direction; it will be much appreciated.
