Micromega M100 Streamer/DAC Amplifier Review
Rate this amplifier:
    Votes: 18 11.5%
    Votes: 77 49.4%
    Votes: 58 37.2%
    Votes: 3 1.9%
This is a review and measurements of the Micromega M100 integrated amplifier with included DAC, EQ/Room Correction, streamer and phono input. It is on kind loan from a member. It is discontinued but while it was a going concern, it cost US $5,800.
Micromega M100 Stereo Integrated Amplifier streamer room EQ Amp Digital Room review.jpg
The M100 is nice looking and comes in a very dense, solid and wide/deep enclosure. The picture doesn't do it justice in this regard.
There are two graphic displays, one in the front and another above which I appreciated. User interface is a bit odd but you get used to it. Part of the complication comes from insane amount of connectivity:
Micromega M100 Stereo Integrated Amplifier streamer room EQ Amp Digital Room back panel french...jpg
I wish the two HDMI connectors were NOT for I2S but for real HDMI. Other than that, you are covered with every sort of input and output and in balanced.
That niceness was forgotten while I struggled to connect all the cables as the top extends an inch or two, fully covering the sockets. This makes for a neat appearance but makes it impossible to plug anything while leaning on top of the unit. And don't make the mistake of using XLR plugs with locking level as you can plug them in, but your finger can't get in there to press the lever to unplug them! I had to use a screw driver to push the pins in to pull them out. For the rest of the cables, I had to put the unit on its top, connect the cables and then rotate it which made a bit of a mess of the cables.
After testing, I went to turn the unit off and noticed humming sound. There appears to be a fan in there with vents on left and right of the unit. Given the massive chuck of metal that the case is, and could act as a heat sink, i was surprised by this. But then again, even with that fan, the case was rather warm.
Micromega M100 Amplifier Measurements
Since there are XLR balanced pre-amp outputs, I decided to run a few tests of the internal DAC:
Micromega M100 Stereo Integrated Amplifier streamer room EQ DAC measurement.png
For an integrated amplifier DAC, this is not bad:
The unit has lots of output capability:
Micromega M100 Stereo Integrated Amplifier streamer room EQ DAC THD vs Level measurement.png
And unlike AVRs, doesn't use any gain staging so higher volume maintains the same performance.
Dynamic range is naturally another "not bad:"
Micromega M100 Stereo Integrated Amplifier streamer room EQ DAC DNR measurement.png
Same story for wideband noise+distortion:
Micromega M100 Stereo Integrated Amplifier streamer room EQ DAC thd vs frequency measurement.png
Moving on to the amplifier, let's start with analog input:
Micromega M100 Stereo Integrated Amplifier streamer room EQ Amp Analog XLR measurement.png
Strange bump in low frequencies which stayed there even with no input signal. Fortunately, it goes away with digital input:
Micromega M100 Stereo Integrated Amplifier streamer room EQ Amp Digital measurement.png
This is solid performance and a bit above average for all amps tested:
Since digital performance is superior, for the rest of the tests I stayed with it.
I wish 5 watt performance was better:
Micromega M100 Stereo Integrated Amplifier streamer room EQ Amp Digital SNR measurement.png
Frequency response test shows no load dependency which indicates some kind of class AB design:
Micromega M100 Stereo Integrated Amplifier streamer room EQ Amp Digital frequency response mea...png
But the input is resampled down to 96 kHz which is fairly typical.
Fair bit of power is available on tap:
Micromega M100 Stereo Integrated Amplifier streamer room EQ Amp Digital Power 8 ohm measurement.png
Micromega M100 Stereo Integrated Amplifier streamer room EQ Amp Digital Power 4 ohm measurement.png
Micromega M100 Stereo Integrated Amplifier streamer room EQ Amp Digital Power 4 ohm max peak m...png
Edit: forgot to include power vs frequency:
Micromega M100 Stereo Integrated Amplifier streamer room EQ Amp Digital Power 4 ohm vs frequen...png
The M100 brings style, solid build quality and excellent connectivity. Measured performance shows competence but nowhere close to state of the art. Fair amount of power is available as is much needed equalization. Price is up there but I suspect it is consistent with their marketing and distribution for an EU produced product.
No sense in recommending the M100 since it is discontinued. But if it weren't, it would be on my list for folks with more than a fast food budget for dinners. :)
Is it just the picture, or are there no labels for inputs / outputs?
That brand was always highly regarded in France, I'm very happy to see one of their products tested.
The design is neat, except for the apparently undispensable fan, which is a no no for me in any amp. The price is of course the real issue here, even though it was 3900€ in France.
The white version looks even better imo
There was a time it was sold about 2k euro street price, probably when it was about to be discontinued.
Absolutely gorgeous form factor back then, pics don't do justice about the premium feeling.
Never a fan of Micromega but that one delivered overall.
Fan is a major no though, no matter what, they could very well put all that real estate in good use.
Thanks Amir!
Hi,
If I am not wrong, Micromega also produced the same but with more power and called it the M150 or M200 (maybe both existed ?).
If was also possible to provide those units with a dedicated Headphone amplifier that was supposed to be very good (on paper, never had a chance to hear it).
Indeed, given the looks of the units, I must say that this would fit into my next home perfectly :)
The labels are actually underneath the box! I really don't know what they were thinking.
Thanks - they probably thought "be different" :facepalm:
Tear down see attached files
If I'm not mistaken, Micromega is a French brand... I've never liked this brand, and I'm French.)
We can see that the amplifier section is a dual-mono configuration with one PSU per channel.
Thanks @amirm. Always wondered about this one !
It is discontinued
Well, my issue is precisely that it wasn't.
Both M100 and M150 remained on sale for quite some time, you still could buy them new even in 2023-24. So what was off with that ? These were still sold labelled as "Amp/streamers", while they absolutely weren't (streamers). The Micromega company almost ceased to exist around the Covid lockdown, and even before that, they completely abandoned any software support whatsoever. So until recently, you still got some 4000€ MSRP "Amp/streamer" for sale, with zero online connectivity working and last update for their App (both iOS & Android) in 2018-2019. Quite a shame, indeed.
It seems that Micromega is recently back on track. Don't know if it is some good news or not. AFAIC, I don't trust this brand, like, at all.
Certainly not in my book, mon ami. ;)
Interesting idea of the radiator "duct", with a fan in the middle. Probably leading to one channel running hotter than the other...
Printing "normal" labels at the rear would have probably been too profane :)
I've seen somewhere a smart solution, double labels at the rear - normal and upside down. Very comfortable.
You should consider a Wiim Amp Ultra for this reason ) not to mention the crazy price charged by Micromega....
It's supposed to be the most effective way (look at Trinnov multichan, it makes miracles, or the top icepower module who does kW)) but it does not makes sense to a small power amp like that.
I mean it has the size and thickness to act like a heatshink just fine.
Now, if they really intended to prolong its life and given the sealed case, maybe it's a good idea.
But not Hi-Fi.
Seeing the name Micromega brings back a memory for me. More than, ooh, 30 years ago, I went in to a local hifi shop to hear this new Micromega player that the press were raving about. I think it was called a Logic? (It was, in fact, just a Phillips player that, in What HiFi parlance, had been "tuned" for audiophile ears.) Anyway, wisely, I took my own budget Phillips CD player with me to compare. They weren't too happy about that. It was on that day I realised I couldn't be bought by the hifi marketing men: it sounded exactly the same as my Phillips, and most memorably, while handling the Micromega, I got some kind of electrical shock!
