A yes i use dual subs for my LS60 and room EQ via ROON or WiiM ( until a thunderstorm killed the WiiM and dozen other things i owned ) and they are bit limited dynamically , but I knew that goin in as i don't listen at wallpaper removing levelsThe LS60 sounded good and relatively tonally balanced. Certainly not bright. I'm sure many could live happily with it.
Here is Manta vs LS60 in the same room. Note that the more tidy bass for the Manta below 100hz is a result of EQ and subwoofer gain adjustment. Below 100hz is in part room dependent, and the bass level can be adjusted by the on-board DSP of the LS60 in a similar way as in a Sigberg system, so that can be adjusted to your liking. So while the bass looks "worse" with LS60 in the graph below, in practice something similar as the Manta graph could be achieved with the LS60 as well.
Not sure that we can read all that much into this. They're not super different tonality-wise. Manta avoids the midbass suckout. LS60 is not very powerful with regards to dynamic capacity compared to any of the Sigberg systems, but that is not very surprising and by design. Manta is also way more expensive.
Both measurements are average of individual left+right measurements and 1/6th octave smoothing.
A good compromise for my use case , I do have a low Q bass shelf from ca 230 Hz with a mild lift to taste
A factor when choosing them was such things as local representation , they are everywhere nowadays ( the active kef's )
Had a college many years ago that where into big cerwinvega's , potted flowers moved around in his house ...
