I compared your company’s speakers with KEF, and they seem quite similar.
Sigberg Audio looks like the kind of speaker I would personally enjoy.
The reduced bass appears intentional, probably because they are designed to be used with subwoofers.
Yes the lack of bass is intentional due to the Manta being a 4-way system with bass modules/subwoofers, and these were not a part of these measurements. I will try to measure anechoically with a subwoofer on our upcoming SBS Generation 2 to paint a more accurate picture of the true response of the system.
From around 1000 Hz and below, the dispersion pattern appears sharply cardioid.
Is there any active DSP correction involved in achieving that dispersion behavior?
No, it is achieved as an effect of the cabinet design and mechanics.
It also looks like they would deliver bass with the kind of punch you normally get from larger speakers.
I don't know what your definition of large speaker is, but the Manta is a relatively large monitor, and you also need two subs to make the full system complete. The midbass driver is a 12".
So the recommended setup with dual 10D subwoofers will be a system with 2x12" midbass drivers covering 90-600hz, and 4x10" (sub)bass drivers covering 20-100hz. So yes, it is relatively punchy.
