Methodical 4-Way Horn Integration in an Attic Room: Time-Alignment & DSP Calibration Workflow (CLIO, Hypex & Dirac Live)
MEGB1262
Hello ASR Community,
i want to share my latest DIY audio project, focusing less on the aesthetics and more on a strict, methodical measurement and calibration workflow
multi-way horn systems are notorious for integration issues, especially when placed in a challenging acoustic environment like an attic with angled ceilings and exposed wooden beams
to tackle this, I implemented a cascaded, three-step DSP and measurement strategy to achieve time-domain precision and a flat in-room response
here is the system overview and the exact technical approach I used:
step A:
time alignment via precision measurements (CLIO Pocket)
horns inherently suffer from massive geometric offsets, leading to significant group delay and phase degradation if uncorrected
  • Methodology:
    using CLIO Pocket, i captured the precise impulse response (IR) and phase of each individual driver
    super-tweeter Visaton TL16H
    210 mm tractrix wood horn with 18sound NSD1480N driver
    420mm tractrix wood horn with DCM414-16 driver
    dual-woofer kick bass with 2X 15 inch Celestion FTR15-3070C drivers
  • Execution:
    by analyzing the exact Time-of-Flight (ToF) differences in the step response, i have calculated the precise millisecond delays needed to perfectly align the acoustic centers
  • Results:
    the drivers here sum perfectly at the crossover regions without phase cancellation precise time alignment after setting the correct delay for the super tweeter to the 210 mm wood horn
step B
driver linearization with the 30 USD autoEQ upgrade of the miniDSP FLEX8DL used as main DSP audio controller
the 3 horns are driven with the separate Hypex FA123 plate amp and need to be coupled correctly to the kick bass
satellite autoPEQ for left Hypex plate amp driving the mid / mid-high / super tweeter horns
left side
right side
the unsymmetrical settings comes from the room placement with the left side near the wall and the right side in the middle of the room and additional manufacturing tolerances for speaker drivers and mechanical tolerances of the wooden horns
for the kick bass chassis the autoEQ do not work well, here i have used a simple manual approach, same PEQ for left and right side
here the resulting frequency graphs for the satellte speakers
left side
right side
it's late today - to be continued
just to be a little more clear the result of the final Dirac Live! room correction, you see very clear that due to the quite different PEQ settings for the left and the right side the left channel has less volume
definitely i need to review this, the L / R channel volume level difference of almost 6 dB ist far too big for only rematching tolerances, i need to recalculate the autoPEQ setting for the left channel
Very cool DIY system!
With this type of system, is a flat in room response tonally correct? Your measurement shows a rising HF. How does it sound?
looks pretty rad.
Cool. You definitely don't need a super tweeter to complement NSD1480N though.
reviewed the autoEQ settings and found the problem
the autoEQ integration in the miniDSP device console looks easy to use but there are some pitfalls with the resulting differences in the volume level if you don't match exactlx the settings of the left and right side chassis
i have also changed the target curve of the Dirac Live! room correction
i can match the target curve to my own preferences anyway through the Roon Muse PEQ filters, here a simple example
here the results in the Dirac Live! project view
next step will be to verify with the CLIO Pocket measuring system what Dirac Live! is really doing with the audio signal
strange behavior to observe is the fact that clicking the Dirac bypass button in the device console or in the remote control leads to a major increase of the latency and not a decrease as expected
my assumption for this ist that the hardware architecture of the miniDSP implementation of Dirac Live! reroutes completely the signal path in the DSP so that with the Dirac bypass they have to go through the entire audio buffer for the mixed FIR filters with presumably 2048 samples at 48 kHz sampling frequency - makes a latency of 42,67 msec
here the device console in action, note that the volume level matches without the need of any correction from the DL room correction
here some more pics of the sound system
the front CB sub and rear CB sub forms a cardioid subwoofer setup together with the 2 N-dipole subwoofer with 4 21 inch drivers
the two 90 degree flipped fullrange speaker dipole arrays are good for the reverberant field improvement, here you can listen quite decently to the sound even standing behind the speakers
Cool system.
I had something not too dissimilar, both in a normal rectangular room and then an attic room.
I built Synergy Multi Entry Horns which work better for me in the space.
Single point source and coherent phase across the HF to LF.
Retained the same tapped horn subs for a 4 way.
