Audionaut
Do you think that only you are allowed to write comments?What’s up with the extra commentary?
Not at all; keep it to the topic maybe? I fail to see a connection to the thread of comments on "intellectual greats" and "world affairs".Do you think that only you are allowed to write comments?
Sorry, my imagination can’t make the leap between your comment and my comment, nor the original.There have been, are and will be bigger issues in the world then any hifi audio reproduction equipment regardless of price, no?The point being, I think, that there are much bigger problems than rich people paying too much for amplifiers in our world today?
But can a number actually tell you how something sounds? Take for instance a person with tinnitus in an anechoic chamber, if you measure the noise level the value is zero, but that is not what the person hears! You see the perception of sound is personal. You simply do not hear what I hear.Of course. Audio equipment is supposed to do nothing to the sound except amplify it (or in the case of a DAC, convert it perfectly from the digital). The tests tell us how well it can do that.
No I buy equipment that sounds nice to me, that is different for each person.So, you buy, and recommend that others buy equipment that exhibits measured defects because you think it sounds better?
Rick "tired of this anecdotal anti-factual logic" Denney
But the human brain doesn't hear numbers? Each brain actually processes what it hears individually, so you cannot predict with a number what another person finds pleasureable.Yea, pretty much. Electronics are mostly solved problems and should deliver completely transparent to the source sound
unless you buy tube products which mostly add tonal changes of their own and even some solid state stuff is designed that way.
To be sure you get something capable of TOTL sound, the measurements from trusted sources like here will tell you that.
Speakers are still a dice roll, some are excellent in providing accurate reproduction, while others have had big tone controls added
to the way they sound either out of ignorance of the designer, or of purposeful tuning in hopes of attracting some listeners who love
that kind of sound. Again measurements from a trusted source will get you in the ballpark of something really good. But even the
best of the ones out there all sound sightly different so being able to hear them first might be a good idea when possible.
But we can isolate whether it is actually the sound waves they find pleasurable or something else. All too often it is the latter.But the human brain doesn't hear numbers? Each brain actually processes what it hears individually, so you cannot predict with a number what another person finds pleasureable.
No but it can tell you if the output is different from the input.But can a number actually tell you how something sounds?
The number can tell us that it doesn't influence the sound audibly at all.But can a number actually tell you how something sounds? Take for instance a person with tinnitus in an anechoic chamber, if you measure the noise level the value is zero, but that is not what the person hears! You see the perception of sound is personal. You simply do not hear what I hear.
The way I use ASR test results is as follows. Numbers have value up to the point of audibility. You can take the data and whittle down choices - take the really bad products out of contention. Then look at the remainder and select something to evaluate at home based on desirable features and cost. Desirable features include: functions, aesthetics, reliability, and support after the sale. For me, it is really that "simple". Oh, one other thing - the initial couple of pages in the review threads have the most value. Past that point, the pointless banter starts and can be safely ignored.But the human brain doesn't hear numbers? Each brain actually processes what it hears individually, so you cannot predict with a number what another person finds pleasureable.
I generally agree, although I'd take it a step further. I do not enjoy salespeople or auditioning equipment, so triage the field further and only go listen to *speakers* and only those that measure well (including my own preference for wider dispersion).You can take the data and whittle down choices - take the really bad products out of contention.
I see your point and I classify that as individual choices. One thing I left out - which becomes important in the case of "broken" purchases - use vendors with generous return policies.I generally agree, although I'd take it a step further. I do not enjoy salespeople or auditioning equipment, so triage the field further and only go listen to *speakers* and only those that measure well (including my own preference for wider dispersion).
Electronics can safely be purchased on measurements and features. If they sound bad when they arrive, something is broken.
Great, to what end?No but it can tell you if the output is different from the input.
Correct it. That is distortion that is not part of the recording. Or don't, but at least you are making an informed choice and go in knowing it is different than they heard in the mixing room. Maybe you don't care, and that's fine too. But I do for my experience.Great, to what end?
Look, as a victim of tinnitus I can say this with confidence: Whatever hearing limitations any one person has is a filter that persists continuously for that person at some level, day and night. Thus, everything I hear goes through that filter, including live music.But can a number actually tell you how something sounds? Take for instance a person with tinnitus in an anechoic chamber, if you measure the noise level the value is zero, but that is not what the person hears! You see the perception of sound is personal. You simply do not hear what I hear.
If the output does not match the input, the device is colouring the sound. The whole point of hi-fi is to reproduce the recorded sound. Now does that mean you cannot salt and pepper to your individual liking - of course not. Do what you prefer. Starting with electronics that are accurate allows you to back out those preferences and land at an accurate starting point again.Great, to what end?
So that the alterations we make to the signal for personal pleasure are deliberate, predictable, and removable, rather than fixed and unpredictable.Great, to what end?
