tmtomh
- Joined
- Aug 14, 2018
- Messages
- 3,505
- Likes
- 10,601
I am just very picky with value ever since picking up day trading
That doesn't make any more sense than your prior comments.
Thanks for the review amirm.
It's an interesting a well measuring loudspeaker. It's a pleasant enough looking unit and is likely to garner more fans on this basis than the Genelec offerings for home users.
I think Mesanovic may have priced it just out of range for people like myself who might consider buying at the £4000.00 a pair mark. It really needs pricing to slightly undercut the other well regard options in this price range in my opinion. Great piece of engineering but just too expensive.
Agree that $1,995 would have been a better price.
lolI am just very picky with value ever since picking up day trading
system-audio.com
I believe they both use a Platin Audio plate amp... also Buchardt A500;Looks like it uses the same plate amplifier / DSP as System Audio "Silver Back" speakers...
Wireless speakers Archives - System Audio - Life-Changing Sound Begins Here
The Silverback series is a complete, active, and wireless music system. These wireless speakers work seamlessly with the Stereo Hub HT control unit.system-audio.com
What looks like a scam?Almost $1000 more expensive than the KH150 while having fewer controls and worse distortion? Looks like a scam![]()
Specifically, this is because the mid does quite a bit of excursion - D&D have compensated for the bass roll off with EQ to make the blend behave itself. Also, it's an 8", not a 10".
If you had a Purifi 8" in there instead it would be a different story since it has something like 50% more linear excursion.
The Purifi drivers aren't really designed for midbass duty. A better solution would be a larger, higher sensitivity driver to also avoid thermal issues, and of course separate drivers for the actual bass, which both we and D&D have done.
We have to keep in mind though that Mesanovic is a small manufacturer
OKCardioid directivity = more directional bass response
Some examples below.
Omni:
View attachment 414534 View attachment 414535
Cardioid:
View attachment 414537 View attachment 414538
CDM65 Omni vs Cardi:
View attachment 414540 View attachment 414539
These directivity graphs extend to ±180° off-axis.
They quite literally tell us what happens behind the speaker.
Is this based on specific thermal compression data of Purifi drivers? Trading off SOTA nonlinear distortion for significantly worse non-linear performance but a theoretical marginal improvement in thermal issues seems rather a pyrrhic victory.
Almost no one is playing 50Hz since waves at 100dB for 6 hours straight.
Excellent performance and definitely not a scam, however unfortunately for the price of 3149 EUR per piece (thus more than one would pay for a pair of Neumann KH 150) in Europe it does not look not very competitive. We have to keep in mind though that Mesanovic is a small manufacturer compared to big players like Neumann or Genelec and the high import duties on overseas products. Small nitpick: I wish Mesanovic (and other manufacturers as well) would provide protective grilles to avoid accidental damage to drivers.
These are certainly very good speakers, but as usual with active speakers, no one knows anything about the DSP design and amplification. Nothing is measured and no SINAD is provided. After that, how can you talk about value for money for a pair of speakers costing over 5000 USD with a two-year warranty for the electronics??""As long as it doesn't change, I won't buy this kind of product.It actually is pretty competetive if you compare it to the real competition, which KH150 is not. CDM65 is a compact 3 way DSP cardioid studio monitor, so obviously mass produced conventional 2 way speaker like KH150 will be cheaper. If you compare it to D&D 8C, Kii Audio Three, SHIVAUDYO Point Zero, GGNTKT Model M1, it's on the low end price wise of the bunch while measuring as good as the ones that are twice as expensive. It's a pretty good deal actually
?These are certainly very good speakers, but as usual with active speakers, no one knows anything about the DSP design and amplification. Nothing is measured and no SINAD is provided. After that, how can you talk about value for money for a pair of speakers costing over 5000 USD with a two-year warranty for the electronics??""As long as it doesn't change, I won't buy this kind of product.
....Two or more subs are required to make use of that cardioid setting:
With just one, it serves no purpose and certainly won't give you cardioid response.
I've never actually needed to do this, but I do have an EV ETX-18P PA subwoofer which supports cardioid response, and it's as easy as enabling it in the menu. There are no extra settings, it just works.
Usually electronics fail during the first year if there is a fault.
Regarding the electronics, they are stock and ready to replace as a unit, if necessary. The website states what kind of amplification is used (Pascal iirc) and the distortion measurements here provide insight in the total distortion measured by klippel nfs.
My experience with active speakers (b&o, genelec) has been rock solid, going on for 15 years now.
Of course you are free to choose passive speakers, but looking at the data that is available to others and myself, I see no reason to worry.
Take close look at the Platin Amp module. I don't really care but maybe you would.Well, I’m just fine with small manufacturers putting big price tags to their products. As long as they don’t carry a »Made in China« on the back, that is.
