- Thread Starter
- #81
The link above says they won't sell to individuals.
Isn't this simply a consequence of dual opposed woofer arrangement?Switching to bass heavy music, brought out the real power. Impressively, the cabinet was not transmitting hardly any vibrations. Typically I have to work fair bit to isolate these when performing my listening tests but with CDM65, I didn't have to.
These are a lot like the Buchardt A10, looks like the same AMP and WISA setup. Similar preference score and bass extension, besides being a 2 way vs 3 way. Any reason to take this over the A10?
The Buchardt is a simple 2-way design and is incapable of cardioid playback.Great question. The Buchardt's seem to be unable to even hit 100 db based on the settings of their limiter in stock tune. IDK if they have a Cardioid tune either, but they definitely have the better appearance.
They do have a Cardioid tune or something like it I believe. Is it the same as the near field tune? Nvmd I see the above post.Great question. The Buchardt's seem to be unable to even hit 100 db based on the settings of their limiter in stock tune. IDK if they have a Cardioid tune either, but they definitely have the better appearance.
I think scam is much too strong a word to use here.I don't know why there's been such a fuss over my opinion that this is a scam. There is simply no universe where this speaker is competitive.
Often its easier and cheaper to run signal than power o in ceiling/wall speakers.removing signal wiring for surround and ceiling speakers.
These were also on my shortlist. The manufacturer claims cardiod to 200 Hz and constant directivity from 250 Hz. Horizontal radiation is wider (140°) than the CDM 65s (120°). The recommended listening distance for the CDM 65 is 0.9-1.8m (3-6 feet), for the M1 it is 1-3m. For me, the listening distance is around 2.2m and at this distance, even without a subwoofer, the distortion in the low frequency range, which was sometimes criticized here, was not noticeable. Maybe the M1s are more suitable for slightly larger rooms? Unfortunately they are also about 2.000 Euro more expensive per pair. What really sets them apart though is the looks. They look elegant without being obtrusive and dominating the room (just my opinion). For an additional charge, for example, the front can be finished in any automotive paint.The one that we're not seeing, unfortunately, is the GGNTKT M1's, which are also cardioid down to 150 hz, come with premium electronics, and some very nice cosmetics. And they are also designed to play louder with lower distortion than the CDM 65's. Unfortunately not sold in the US, and not likely to be anytime soon.
I have power all around room but no signal wires. Agree if you have to run them low volt 8s easier.Often its easier and cheaper to run signal than power o in ceiling/wall speakers.
Or just using rear or side openings with adjusted damping material before in the enclosure which act as acoustical delay elements like for example Geithain very successfully does on their K models as well as D&D on their 8c (their rear woofer isn't used for their cardioid upper but to reduce the SBIR problem from the front wall distance)The Buchardt is a simple 2-way design and is incapable of cardioid playback.
For that, additional side- or rear-firing woofers are required.
www.audiosciencereview.com
Those vents introduce steep roll off below a certain tuning frequency. Even with a 10'' midrange driver, D&D 8C struggles to output decent SPL around 100 ~ 150hz at 1% distortion. Buchardt would require significantly larger midrange woofers to use delay vents.Or just using rear or side slots with mechanical absorbers before in the enclosure which act as acoustical delay elements like for example Geithain very successfully does on their K models.
Here is also a very interesting analysis on such:
"Analysis" of cardioid speaker radiation via lateral slots - like D&D 8c
First off, I want to temper expectations, I'm certainly not a cardioid radiation expert - but will do my best. I can only touch on a few topics and if something interesting comes up I will expand the post if necessary. Index 1. Does it work? 2. Comparison speaker with slots to "normal" speaker...www.audiosciencereview.com
Yes, even the 12" Geithain RL 921K and 15" RL 901K are not SPL monsters in the bass also due to that.Those vents introduce steep roll off below a certain tuning frequency. Even with a 10'' midrange driver, D&D 8C struggles to output decent SPL around 100 ~ 150hz at 1% distortion. Buchardt would require significantly larger midrange woofers to use delay vents.
Specifically, this is because the mid does quite a bit of excursion - D&D have compensated for the bass roll off with EQ to make the blend behave itself. Also, it's an 8", not a 10".Those vents introduce steep roll off below a certain tuning frequency. Even with a 10'' midrange driver, D&D 8C struggles to output decent SPL around 100 ~ 150hz at 1% distortion. Buchardt would require significantly larger midrange woofers to use delay vents.
Also the Mesanovic has a more continuous PIR and sound power due to its wider directivity and better vertical radiation:
I am just very picky with value ever since picking up day tradingThis is some of the weirdest, most baffling and irrelevant ranting I've seen on a review thread yet. Well done.
Agree that $1,995 would have been a better price.Thanks for the review amirm.
It's an interesting a well measuring loudspeaker. It's a pleasant enough looking unit and is likely to garner more fans on this basis than the Genelec offerings for home users.
I think Mesanovic may have priced it just out of range for people like myself who might consider buying at the £4000.00 a pair mark. It really needs pricing to slightly undercut the other well regard options in this price range in my opinion. Great piece of engineering but just too expensive.
