Maiky76
Here is my take on the EQ.
Please report your findings, positive or negative!
For the score rational your journey starts here
Explanation for the sub score
The following EQs are “anechoic” EQs to get the speaker right before room integration.
If you able to implement these EQs you must add EQ at LF for room integration, that is usually not optional… see hints there.
The raw data with corrected ER and PIR:
Score no EQ: 6.8
With Sub: 8.2
Spinorama with no EQ:
Directivity:
EQ design:
Score EQ Score: 6.9
with sub: 8.4
Spinorama EQ Score
Zoom PIR-LW-ON
Regression - Tonal
Radar no EQ vs EQ score
No improvements
Score no EQ: 6.8
With Sub: 8.2
- Great
- Probably does not an EQ
Directivity:
EQ design:
- One EQ LW/Score are the same
Score EQ Score: 6.9
with sub: 8.4
Code:
Mesanovic CDM65 APO EQ Score 96000Hz
December172024-103917
Preamp: -3.00 dB
Filter 1: ON PK Fc 60.8 Hz Gain 1.80 dB Q 1.98
Filter 2: ON PK Fc 479.2 Hz Gain -1.50 dB Q 3.54
Filter 3: ON PK Fc 1358.5 Hz Gain 0.62 dB Q 0.30
Filter 4: ON PK Fc 16924.1 Hz Gain 2.92 dB Q 0.82
Spinorama EQ Score
Zoom PIR-LW-ON
Regression - Tonal
No improvements
Mesanovic CDM65 3D surface Horizontal Directivity Data.png384.2 KB · Views: 157 -
